This Post has more than one question on this TOIPC of...CD BATTERY STUD WELDER. — Parallax Forums
sam_sam_samsam_sam_sam Posts: 2,286
edited 2010-05-27 02:56 in General Discussion
Has anyone every made a CD battery stud welder using a microwave oven transformer Looking for info
Also looking for any idea.gif·
I have a lot of surplus Ni-cad batteries and Li-lion batteries that I need to make in to battery packs
I can have a battery repair shop do them however they charge $ 1.50 per cell
So i want to built a welder to do this my self
·Now wanting to learn Spin· Thanks for any·idea.gif·that you may have and all of your time finding them smile.gif
Sam
Post Edited (sam_sam_sam) : 5/25/2010 2:43:40 PM GMT
    edited 2010-05-25 08:49
    It's hard to connect wires to those batteries. I was always
    scared to heat them up for several seconds to solder them because I thought the battery
    might explode or something...the metal is smooth and solder seems to hate to stick to them.
    I wonder if you were to sand the battery terminals with
    something like an emery board if you could then get solder
    to stick to them quickly and avoid heating the battery up
    so much?
    Maybe wear goggles if you try it just to be safe.
    edited 2010-05-25 13:50
    HollyMinkowski
    Thank you for your reply
    Yes it is hard to do this because i have try this my self
    so much?
    I·have also try this as well and really dose not do·any better
    I wear eye·safety glass to see and read with any way but yes to that as well
    Sam
    edited 2010-05-25 14:16
    Sam, you should delete your other post.
    - Stephen
    edited 2010-05-25 14:31
    Which one would be better to use and why---->>>
    A··· SCR· ·or a··· TRIAC ?
    ·I want· to control the Power Transformer for this project with a Basic Stamp· any ·idea.gif·s
    Thanks to any one that can help
    Sam
    Post Edited (sam_sam_sam) : 5/25/2010 2:46:12 PM GMT
    edited 2010-05-25 15:27
    As to the batteries exploding if they get too hot from soldering, I can say from experience that yes, they do.
    BTW, I don't think a microwave oven transformer is what you want for this. For a welder, you need a low voltage at high current, not a high voltage at low current.
    edited 2010-05-25 15:58
    sam_sam_sam,
    ...for connecting your battery terminals, try looking up 'spot welding' or 'tack welding'. The finish on the battery terminals you mention is usually Nickle, so you need a solder chemistry that is compatible with that and the wire you wish to attach. Silver solder paste is usually a good candidate for this.
    Beau Schwabe
    IC Layout Engineer
    edited 2010-05-25 18:29
    Phil
    Yes this can be do with using a· microwave oven transformer
    but you have to replace the secondary winding with a· 2 - 20· turn of wire for the secondary winding··using at least a # 10· wire
    Here is a link that show how you can use a home made one
    http://www.youtube.com/watch?v=VG1xVNpm7k8&feature=player_embedded
    Here is a link on how you make one
    http://hackaday.com/2009/06/23/how-to-build-your-own-spot-welder/
    Sam
    Post Edited (sam_sam_sam) : 5/25/2010 7:06:20 PM GMT
    edited 2010-05-26 13:38
    The transformer from a soldering gun is an excellent choice for this type of resistive soldering. For safety make sure one side of the secondary winding is grounded.
    edited 2010-05-26 15:13
    kwinn
    Thanks for this· idea.gif·I saw this· while reseaching for stud welders
    But I was not sure if this would work or not
    I will give this a try
    Sam
    edited 2010-05-26 17:45
    I have Used MOTs for Hi Amp use [noparse]:)[/noparse] I used flat 1/4 Cu tubing with 2 layers of heatshrenaik on them .
    I solder My NiMh Cells with Jumbo wick or Tinned Cu braid .
    I use a solder gun to heat it up . and I use a Dremmel to get the tops clean .
    As for CD based . I woud recemend a SCR . a BIG SCR I have a 1.4kA 2.5kV one here on my desk [noparse]:)[/noparse]
    A lkarge Stud type would be big enough .
    If I had to make one I would Still use a MOT but with a Switch on the 120V side and a BIG Diode on the secondary side . the MOT with Thick wire can do 100s of amps so it sould be enough for a AA batt cell IMHO .
    Peter KG6LSE
    "Carpe Ducktum" "seize the tape!!"
    peterthethinker.com/tesla/Venom/Venom.html
    Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
    LOL
    Post Edited (Peter KG6LSE) : 5/26/2010 5:50:35 PM GMT
    Sam,
    Pick up a copy of the latest (June 2010) Nuts & Volts. I just got mine today, and there's a circuit in there for a home-built spot welder.
