Questions about the 12V motor mount kit with encoders
I have a few questions about the 12V Motor Mount Kit with encoders.
1. Can the resolution of the encoders be increased by changing the black spoked wheel to get something like 1 degree precision?
2. How big is the slop in the motor gears? About 1 degree or more?
I am thinking of getting a kit to build a balancing robot. Is this feasible or not? Will the gears strip from the too many direction changes? I estimate the robot will weigh about 15kg.
Thanks in advance.
Thanks in advance.
To increase the resolution I think you would need a larger diameter encoder disk - so that the tabs remain the same size and distance apart, just more of them.
Otherwise, maybe a replacement disk with double the number of tabs (each half the normal width) would work but may require more careful alignment - don't know if that would work or not, seems plausible.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
Maybe it's something more like this inside there? http://www.ul.ie/~nolk/Ken8.gif
They also do have a little bit of "play" in them, just a few degrees though.
Check out the Propeller Wiki·and contribute if you can.
Trust erco, they are worm gear windshield wiper motors adapted for a robotics application. I have a set and they have worked fine for my robotics application. See the Parallax article in Robotics mag.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
I posted because the OP asked specifically about a balancing robot, and also about how much slop was in the wheels. In the case of a balancing robot where the wheels are constantly reversing direction (especially standing still), and there will be ten (probably more) times the number of fwd/reverse cycles of a non-balancer. The worm gear's sliding motion will wear faster than spur gears and the "slop" will increase at an accelerated rate in a balancer. Increasing gear backlash will introduce new stability problems.
This is the best illustration of the gearbox I could find.
Rich H
Post Edited (W9GFO) : 5/27/2010 6:40:01 PM GMT
I have been building Lego robots (and "sheet metal" robots) so I know exactly how a worm drive works, as I have used this setup in my Lego robots many times. I am working now on several different projects and a balancing robot is on the way. But I still haven't found proper motors for it. I want strong enough motors that do not use planetary gearboxes (they are notoriously noisy) with a back shaft or built in encoders. I would like to use 6" or 8" wheels and the estimated weigh of the robot is about 30 lb and about 3 feet tall. It's always good to have some spare power to be able to climb an incline like the handicapped inclines we find at the entrance of the buildings.
If any of you guys have experience with motors and can recommend me something suitable I would really appreciate it.
Thank you in advance for your recommendations.
