Problem with 30 watt solar panel
I am a student working on the project which we decided to use parallax solar panel kit (#33000) as a charger on a robotic vehicle. We encounter some problem with our solar panel output.
The power produce by our solar panel is not as expected from the results stated in the instruction manual.
value in manual:
Open circuit
voltage 7V
current 4A
result under strong sun lights
voltage 6.57V
current 16mA
We follow the instruction carefully and did not find any errors in our solar panel. We would like to know what is our problem in our solar panel as we did not get enough current from it. Thanks in Advance![noparse]:)[/noparse]
value in manual:
Open circuit
voltage 7V
current 4A
voltage 6.57V
current 16mA
From your readings, it looks like the panel voltage is very close to the battery voltage. You need a potential difference of a few volts to drive the current into the the battery.
Also, the panel cannot deliver 4A at open circuit conditions. The write up states maximum power at 6 VDC and 4.9 amps.
Cheers,
Tom Sisk
http://www.siskconsult.com
As for my reading, It was mention in the instruction manual that it not uncommon to have 7volt and above but the current is way too low for it be of any practical use. I actually did a test with a small LED and 270ohm resistor connected in series and it produce 5.963V, 13.77mA.
You could use three solar panels in series along with a charging regulator to charge your battery. There are lots of charging regulators on the market for use with solar panels. You'll have to do some research to find one for the type of battery you're using.
May i know is there anyone here using the same solar panel?
It would be a great help if u can share your voltage and current reading here so can can make a comparison.
Unless you describe how you're making the measurements, they're meaningless.
Is my way of my measurement wrong?
thanks for you guys' help!much appreciated
What you previously were measuring was the LED current, not the panel output current.
Cheers,
Tom Sisk
It was place under the sun for approximately 30min and i got a average measurement of 2.6V and 1.33A.
May i know does my reading look normal compare to others who is also using this solar panel?
You need to take into consideration the internal resistance of the solar panel and that it changes depending on what your load is.
The numbers you got are probably typical of using a 1.2 Ohm resistor in series with your ammeter making the load resistance actually closer to 2 Ohms.
With a load of 2 Ohms and an internal resistance of about 2.5 Ohms your numbers of 2.6V and 1.33A work out.
I would do it a slightly different way... measure the resistance without it being a load, and then just measure the voltage across that resistance while it is a load. Use Ohms law to calculate current, the ammeter can introduce additional resistance (mostly in the test leads themselves) ... the higher the current the more this can become a problem.
I have not characterized the 30 Watt solar panel, but I have taken a look at our 1 Watt panel. The concept is the same. If you look at where the mid voltage should be, THIS is where most of your power is, but keep in mind half of that power is dissipated within the panel itself, while the other half is dissipated to your load. There is a sweet spot where you will see the most amount of power able to be delivered to the load but each solar cell type (chemistry, i.e. poly crystal or amorphous crystal) has a different characteristic here and where it matters is what the internal resistance is doing based on the load demand.
I don't have a 30Watt panel, but perhaps when I'm out there for the expo at the end of this month I can characterize our 30 Watt panel as well as some of our other panels.
I have included a screen shot as well as the actual Excel program. (change the x1s extension to xls) None of the cells are locked, so you can see the formulas, but you should only need to enter data in the 'green' fields. All of the other fields, including the graph should automatically update.
Beau Schwabe
IC Layout Engineer
