This Post has more than one question on this TOIPC of...CD BATTERY STUD WELDER.
Has anyone every made a CD battery stud welder using a microwave oven transformer Looking for info
Also looking for any
I have a lot of surplus Ni-cad batteries and Li-lion batteries that I need to make in to battery packs
I can have a battery repair shop do them however they charge $ 1.50 per cell
So i want to built a welder to do this my self
I want tp thank anyone that can help
·Now wanting to learn Spin· Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 5/25/2010 2:43:40 PM GMT
·I have a lot of surplus Ni-cad batteries and Li-lion batteries that I need to make in to battery packs
Sam
scared to heat them up for several seconds to solder them because I thought the battery
might explode or something...the metal is smooth and solder seems to hate to stick to them.
I wonder if you were to sand the battery terminals with
something like an emery board if you could then get solder
to stick to them quickly and avoid heating the battery up
so much?
Maybe wear goggles if you try it just to be safe.
Thank you for your reply
It's hard to connect wires to those batteries. I was always
Yes it is hard to do this because i have try this my self
so much?
I·have also try this as well and really dose not do·any better
I wear eye·safety glass to see and read with any way but yes to that as well
Sam
- Stephen
A··· SCR· ·or a··· TRIAC ?
·I want· to control the Power Transformer for this project with a Basic Stamp· any ·
Thanks to any one that can help
Sam
Post Edited (sam_sam_sam) : 5/25/2010 2:46:12 PM GMT
BTW, I don't think a microwave oven transformer is what you want for this. For a welder, you need a low voltage at high current, not a high voltage at low current.
...for connecting your battery terminals, try looking up 'spot welding' or 'tack welding'. The finish on the battery terminals you mention is usually Nickle, so you need a solder chemistry that is compatible with that and the wire you wish to attach. Silver solder paste is usually a good candidate for this.
Beau Schwabe
IC Layout Engineer
Yes this can be do with using a· microwave oven transformer
but you have to replace the secondary winding with a· 2 - 20· turn of wire for the secondary winding··using at least a # 10· wire
Here is a link that show how you can use a home made one
http://www.youtube.com/watch?v=VG1xVNpm7k8&feature=player_embedded
Here is a link on how you make one
http://hackaday.com/2009/06/23/how-to-build-your-own-spot-welder/
Sam
Post Edited (sam_sam_sam) : 5/25/2010 7:06:20 PM GMT
Thanks for this·
But I was not sure if this would work or not
I will give this a try
Sam
I solder My NiMh Cells with Jumbo wick or Tinned Cu braid .
I use a solder gun to heat it up . and I use a Dremmel to get the tops clean .
As for CD based . I woud recemend a SCR . a BIG SCR I have a 1.4kA 2.5kV one here on my desk [noparse]:)[/noparse]
A lkarge Stud type would be big enough .
If I had to make one I would Still use a MOT but with a Switch on the 120V side and a BIG Diode on the secondary side . the MOT with Thick wire can do 100s of amps so it sould be enough for a AA batt cell IMHO .
Peter KG6LSE
"Carpe Ducktum" "seize the tape!!"
peterthethinker.com/tesla/Venom/Venom.html
Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
LOL
Post Edited (Peter KG6LSE) : 5/26/2010 5:50:35 PM GMT
Pick up a copy of the latest (June 2010) Nuts & Volts. I just got mine today, and there's a circuit in there for a home-built spot welder.
