grounding together different battery types
I am using a 6 V battery pack consisting of AA Ni-MH rechargeable batteries to power a servo and a rechargeable 9 V battery for the Basic Stamp. I have the grounds from these separate supplies soldered together (someone·told me to do this a·while ago)·and I was wondering if this is bad? If you are supposed to do this, I do not understand why. My 9 V battery loses charge and heats up, drops to 6.3 volts after a few minutes and I don't know if the connected grounds might be the problem. I have tried multiple fully charged 9 V batteries so I know the fault is not with the batteries themselves. I measured the resistance between the 5 V regulated voltage from the BS2 and ground, and it was 8 kohm--is this normal? why should there be a resistance here?
Thanks!
Thanks!
So yes, you must have the grounds hooked together. They don't have to actually be hooked to each other but they must both connect to ground.
If your 9 volt is being used up so quickly I would check your wiring to be sure that the servo is drawing from your 6 volt pack and not the 5v regulated output.
Yes, there should be resistance as measured from the regulator to ground. Otherwise it would be a short circuit.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
Rich H
