PINGs on robot freezing?? Servos are not to blame! HELP ME!!!
Sorry for the odd title. I have a robot that I have built that has 2 PING's, an Xbee, an SD card and audio out. The robot is moved by 2 Parallax continuous rotation servos. I am powering it all off 4 D cells. The robot will relay sensor information back to the home through the Xbee, and the home commands the robot with simple 1 byte serial commands. My problem is: The ping's will be working for a while, then all of a sudden the lights will stop flashing and data will stop being returned. I can't figure any reason for this happening, as I once thought that it was the servos, but after isolating the servos from the program and making my own servo driver, and I made both a serial and analog one, it still happened. I then tryed decresing the speed of the reads on the PINGs. No luck. I've tryed everything that I can think of and there still seems to be no rhyme or reason to what is happening. I am using Kye's duel servo driver and the default PING driver. I know that it is not the home end because it acts the same if controlled by typing the commands in on a PC terminal. Can someone help?? Here's the code:
As you can see the sound and SD card are not used in this program.
Thanks in advance,
Micro
Check out my new website!!
Use the Propeller icon!!
Follow me on Twitter! Search "Microcontrolled"
''This is version 2 of the RC bot. This version allows it to be fully automated, and turned on and off
''(the automation) from the transmitter. It can not be turned back manuel from the remote at this
''time. The RC bot also features a park function (2 PINGS needed) that will park itself in a corner and
''sleep until the sound sensor is triggered.
''Version 2.2 has lots of added wireless commands that give the controller full power and monitoring
''over the robot.
''Version 2.3 corrects a bug that was case conflicts on the incoming characters. Now they have been moved
''to hexadecimal values.
''Version 2.4 lets the control see values bigger then a byte length by changing the value from inches
''to feet automatically and by adding in a type byte.
''Version 2.5 removes the features of 2.4 due to no functionallity, and it improves the autopilot by
''allowing it to use both the front and side sensor to know what direction to turn, or if it is drifting
''into a wall due to slightly unbalenced servos.
''Version 2.6 removes conflicting between the PINGs and the rest of the program by putting them in a
''seperate cog.
''Version 2.7 added FSRW and Rayman's WAV player. Also have adapted code to use the SD/sound card
''I built for the robot.
CON
_CLKMODE = XTAL1 + PLL16x
_XINFREQ = 5_000_000 '80Mhz clock rate
Ppin = 0
speed = 0
buffSize = 100
VAR
long state
long cstate
long stack[noparse][[/noparse]20]
long minutes, seconds
byte time
long dist
long side
byte type
''///////////WAV player vars////////////////////////////////////////////////////
long parameter1 'to pass @buff1 to ASM
long parameter2 'to pass @buff2 to ASM
long parameter3 'to pass sample rate to ASM
long parameter4 'to pass #samples to ASM
long buff1[noparse][[/noparse]buffSize]
long buff2[noparse][[/noparse]buffSize]
byte Header[noparse][[/noparse]44]
OBJ
servo : "servoEngine"
ping : "Ping"
xb : "Xbee_Object"
sd : "fsrw"
PUB Start | i, cntn
xb.start(8,9,0,9600)
servo.servoEngine
time := 5
sd.mount(16)
cognew(GetPing,@stack)
Manuel
PUB Manuel
' state := @idle
'cstate := @man
servo.SetPositionA(90)
servo.SetPositionB(90)
' Automatic
repeat
case xb.rx
"u":
xb.tx($FA)
servo.SetPositionA(0+speed)
servo.SetPositionB(180-speed)
'state := @active
"d":
xb.tx($FA)
servo.SetPositionA(180-speed)
servo.SetPositionB(0+speed)
'state := @active
"r":
xb.tx($FA)
'state := @active
"l":
xb.tx($FA)
'state := @active
$FD:
xb.tx($FA)
'state := @idle
$0A:
reboot
$0B:
time := xb.rx
' $0C:
' speed := xb.rx
$0D:
'state := @dormant
Nap
"i":
waitcnt(clkfreq/50 + cnt)
xb.tx(dist)
xb.tx(side)
xb.tx(speed)
xb.tx(ina[noparse][[/noparse]10])
"I":
xb.dec(dist)
xb.dec(side)
xb.dec(speed)
xb.dec(ina[noparse][[/noparse]10])
"a":
xb.tx($FA)
cognew(Timer,@stack)
Automatic
$0F:
xb.str(string("Distance from objects: "))
xb.dec(ping.Inches(Ppin))
xb.str(string(13,"State: "))
xb.str(state)
xb.str(string(13,"Control: "))
xb.str(cstate)
PUB Automatic | count
servo.SetPositionA(0)
servo.SetPositionB(180)
repeat
if xb.rxcheck == "M"
Manuel
if xb.rxcheck == "P"
Park
if side < 6
servo.SetPositionA(180)
waitcnt(clkfreq/3 + cnt)
if dist < 36
side := ping.Inches(1)
if side < 48
else
servo.SetPositionB(0)
repeat
dist := ping.Inches(Ppin)
waitcnt(clkfreq/100 + cnt)
count++
if count == 700
Start
if dist > 48
Automatic
if minutes == time
Park
PUB Park | edge
repeat
if dist =< 12
quit
repeat
if side =< 15
quit
repeat
if side =< 10
waitcnt(clkfreq/20 + cnt)
if side => 13
if side > 18
Park
if dist <= 12
Sleep
PUB Sleep
repeat
if ina[noparse][[/noparse]10] == 1
Automatic
PUB Nap
dira[noparse][[/noparse]12]~~
outa[noparse][[/noparse]12]~
repeat
waitcnt(clkfreq*2 + cnt)
outa[noparse][[/noparse]12]~~
waitcnt(clkfreq/300 + cnt)
if ina[noparse][[/noparse]11] == 1
quit
return true
PRI GetPing
repeat
PRI Timer | dT, T
dT := clkfreq
T := cnt
repeat
T += dT
waitcnt(T)
seconds ++
if seconds == 60
seconds~
minutes++
Thanks in advance,
Micro
··- Sparks
The ping and timer cogs use the same stack - will cause problems, you need 2 stacks one for each.
