Tangerine Microtan 65 - 6502 — Parallax Forums
pullmollpullmoll Posts: 817
edited 2010-06-13 10:43 in Propeller 1
I thought I should post what I've done, just in case my HD crashes...
Actually I could use some help fixing the q6502 core I wrote. The machine I'm trying to emulate is the Microtan, a very simple 6502 computer. The CPU core is based on MAME's 6502 implementation, which is actually a 6510. The 6510 has only a few really invalid opcodes and a lot of rather obscure opcodes. The C64 demo folks certainly know them.
Anyway, the current state is this: The code seems to start up the TANBUG in ROM, which prints a TANBUG logo in the last line and scrolls the screen. Then an empty line with a cursor is displayed and the screen is scrolled again.
The first bug to find is why the 2nd half of the screen gets filled with 00s (square glyph) instead of the contents of the rows below. This could be due to an error in indirect addressing or the INC/DEC opcodes. I haven't disassembled the code to see how the scroll loop is done.
The screen memory is 512 bytes at $200..$3ff, which gives an amazing 32x16 character resolution. Each character position has a 9th bit associated with it that tells, if instead of text a block graphics should be displayed. If this is the case, a 2x4 block graphics consisting of 4x4 size poxels (= 8x16 font size) is displayed. The "graphics" resolution thus is 64x64 pixels.
The graphics mode is enabled by reading $BFx0/4/8/c and disabled by writing $BFx3/7/b/f, where x = c/d/e/f, i.e. incomplete decoding of the address lines.
The ROM and the character generator are included. If you put the MICROTAN.CHR on the SD, it will be loaded. This isn't necessary as the default font is hard coded in the VGA driver.
There currently is a waitcnt(clkfreq/256) in the fetch opcode loop, so you can see how the display is scrolled. You can remove it in q6502.spin if you fix the bug smile.gif
Enjoy!
v0.1.2: Add keyboard support. You can enter commands into Tanbug now.
v0.1.3: Included support to load *.M65 files. A few are included. Unfortunately all games require a PIA setup connected to some digital (Atari) Joystick, which isn't emulated yet.
v0.1.4: The scrolling bug vanished after I tried to add debug code to m6502. Is the output of Tanbug giving the command "LC000,0" supposed to be as slow as it is?
v0.1.5: Fixed the slowdown. It was caused by not clearing the IRQ when the interrupt was taken. Probably a missing acknowledge for the keyboard interrupt!?
Pullmoll's Propeller Projects
Post Edited (pullmoll) : 6/3/2010 5:17:52 PM GMT
  • heaterheater Posts: 3,370
    edited 2010-05-18 16:52
    Good grief PullMoll. I've been scratching my head since you posted this trying to remember where I know the Microtan from. Well of course it's from the old days of hanging around the famous Henrys Radio shop on the Edgeware Road in London. About the only place that had them. In the days when Henrys used to sell TTL chips and Nixie tubes and other useful stuff. After 65 years there is still a Henrys Shop there www.henrys.co.uk/shopinfo.htm
    edit: I need not have scratched my head so hard just noticed you have the wiki link there that says exactly that.
  • LeonLeon Posts: 7,620
    edited 2010-05-18 17:00
    Henry's was still there last year when I had some time to kill in London. I used to buy components there in the late 1950s, when I was at school; I remember buying a couple of red spot (surplus) germanium transistors for 10/- each.
    Leon Heller
    Amateur radio callsign: G1HSM
  • pullmollpullmoll Posts: 817
    edited 2010-05-18 17:25
    Leon said...
    We have a probably similar institution over here in Bonn. My liq^H^H^Helectronics shoppe is P+M Elektronik. I've been going there since I was 8 or 9, so that was mid 70s, and the shop existed (perhaps long) before. I got an electronics experimenting kit for christmas. I don't remember what I bought. It was something I ruined on that kit (Cosmos Electronic).
    Post Edited (pullmoll) : 5/18/2010 5:30:58 PM GMT
  • AleAle Posts: 2,363
    edited 2010-05-18 17:38
    Pullmoll: luckily COSMOS is still doing some kits. I saw them at M
  • mikedivmikediv Posts: 825
    edited 2010-05-18 18:38
    pullmoll that is awesome I was waiting for something like this as much as I like CPM I cut my teeth on the 6502 and was actually in the process of wire wrapping a board ,without much luck I was hoping I could run Flex but I have no schematics showing a floppy interface.
  • trodosstrodoss Posts: 577
    edited 2010-05-18 18:49
    @pullmoll
    In the Hydra section, there was a NES emulation that emulated the 6502.· It may/may not be useful to you on this project.
    http://forums.parallax.com/showthread.php?p=871551
    --trodoss
    Visit the Propeller Powered SIG·fourm kindly hosted at Savage Circuits
    Game(s) Mythic Flight
    Utilities Font Editors (AIGeneric, Potato_Text, etc.)
    edited 2010-05-18 19:01
    Leon
    The first transistor I used to play with was a White Spot. I think it was that situation, of having just one transistor, which started my habit of scrounging and then using everything over, and over ....
    My father wanted to get me off of valve stuff, I should have stuck with them, there's good money in bottle amps now.
    Transmitters had a few of the giant jam jars, so all was not lost
    Wan't the Mirco tan something to do with Elektor?
    Style and grace : Nil point
    edited 2010-05-18 19:03
    trodoss said...
    In the Hydra section, there was a NES emulation that emulated the 6502. It may/may not be useful to you on this project.
    Thanks! The NES didn't have a 6502, but a N2A03. Very similar, and yet different in many regards. Most importantly it had no decimal mode.
    No, what I need is a clue at the code that is going wrong. I found the function that does the scrolling:
    0000FA38: A2 00              ldx  #$00
    0000FA3A: BD 20 02           lda  $0220,x
    0000FA3D: 9D 00 02           sta  $0200,x
    0000FA40: E8                 inx
    0000FA41: D0 F7              bne  $FA3A
    0000FA43: BD 20 03           lda  $0320,x
    0000FA46: 9D 00 03           sta  $0300,x
    0000FA49: E8                 inx
    0000FA4A: E0 E0              cpx  #$E0
    0000FA4C: D0 F5              bne  $FA43
    0000FA4E: 86 0A              stx  $0A
    0000FA50: A9 03              lda  #$03
    0000FA52: 85 0B              sta  $0B
    0000FA54: A9 20              lda  #$20
    0000FA56: A8                 tay
    0000FA57: 88                 dey
    0000FA58: 91 0A              sta  ($0A),y
    0000FA5A: D0 FB              bne  $FA57
    0000FA5C: 60                 rts
    So for some reason the second part with lda $0320,x and sta $0300,x goes wrong. I don't yet know if the 00s are read or written. I have to trace that piece of code.
    Edit: I didn't even know that STA ABS,X doesn't do a page wrap when LO(ABS)+X > $ff. This isn't the cause of the problem, though.
    Post Edited (pullmoll) : 5/18/2010 7:14:31 PM GMT
    edited 2010-05-18 19:32
    Toby Seckshund said...
    I don't think so, or otherwise the Wikipedia article would have mentioned that fact.
    The Elektor had an even earlier, pre-microprocessor project to run games. I don't remember the name of that thing. It was too expensive anyway with dozens of TTLs.
    edited 2010-05-18 19:47
    pullmoll said...
    I will be the first to admit my ignorance [noparse];)[/noparse]
    Just goes to show that there were so many clones/variants to the 6502.
    Here's hoping that the next one is the Apple ][noparse][[/noparse] [noparse];)[/noparse]
    edited 2010-05-18 19:51
    I think I was remembering their Junior Computer, which could look a bit like it with a motherboard attached.
    I never got on with 6502 etc, I was too locked into Z80 (thoughtwise, and moneywise sad.gif )
    edited 2010-05-18 19:57
    Toby:
    Henry's sold white spot ones as well as the red spots. The white spots were intended for IF amps, IIRC, the red spots were AF only.
    I always preferred the Z80, as well. It made a much better embedded controller.
    Leon Heller
  • Ahle2Ahle2 Posts: 1,179
    edited 2010-05-18 21:03
    I have done an emulation of the HuC6280 CPU a couple of years ago for my PCe / Turbo Grafx 16 emulator (btw, soon to be ported to android).
    It's a variant of the 6502 with a MMC, PSG, Timer and some extra opcodes.
    Then I have done two 6502 cores for my SID-player.
    My experience with 6502 emulation is as follows:
    If you have an error in your cpu emulation, it's 90% certain to be an addressing mode issue.
    edited 2010-05-18 22:32
    Leon
    Now you mention it was a red spot that I had. When I wanted another they had stopped stocking them in the Half width shop in Bristol and were supplying GET45, I think, I bought an OC71 but it was nothing better than a noise generator.
    The GET45 was so leaky that it was self biasing, with a couple of coils, and nothing else, I had a 100KHz osc. The youth of today just do not know how much things have progressed ( and I'm "only" 52 )
    My father had some MATxxx transistors which were ok to 150MHz, at that time, I think that they were still a bit "militry" then. I wasn't allowed to use them.
    edited 2010-05-19 02:41
    While reading this thread I tracked down the N2A03 and found this interesting link with a whole stack of disassemblers for different processors written in C for the MAME project. I have had a great deal of experience with 6502 8 and 16-bit variants but one of the first processors that I played with was the Signetics 2650. Guess who on this thread wrote it?
     *  Portable Signetics 2650 disassembler
     *  Written by J. B?????????? (pullmoll@t-online.de)
     *  for the MAME project
    *Peter*
    edited 2010-05-19 03:17
    Peter Jakacki said...
    Yep, that was one of Aaron's goals: a universal disassembler. I used it to disassemble the Microtan code fragment. It has an impressive list of supported CPUs:
    Supported architectures:
      adsp21xx   hyperstone x86_64     m68000     mips3be    sh2        tms57002
      alpha8201  esrip      konami     m68008     mips3le    sh4        tms7000
      arm        f8         lh5801     m68010     psxcpu     sharc      upd7810
      arm7       g65816     lr35902    m68020     r3000be    sm8500     upd7807
      arm7thumb  h6280      m37710     m68030     r3000le    spc700     upd7801
      asap       h8         m6502      m68040     nec        ssem       upd78c05
      avr8       hd6309     m65sc02    m6805      pdp1       ssp1601    v60
      ccpu       i386       m65c02     m6809      tx0_64kw   t11        v70
      cdp1802    i4004      m65ce02    mb86233    tx0_8kw    tlcs900    v810
      cop410     i8008      m6510      mb88xx     pic16c5x   tms0980    z180
      cop420     i8085      deco16     mcs48      pic16c62x  tms1000    z80
      cop444     i80286     m4510      upi41      powerpc    tms1100    z8
      cp1610     i8086      m6800      i8051      rsp        tms32010
      cquestsnd  i960       m6801      i8052      s2650      tms32025
      cquestrot  jaguargpu  m6802      i80c51     saturn     tms32031
      cquestlin  jaguardsp  m6803      i80c52     sc61860    tms32051
      dsp32c     x86_16     hd63701    ds5002fp   scmp       tms34010
      dsp56k     x86_32     nsc8105    minx       se3208     tms34020
    Signetics 2650 is among the CPUs what Forth is among the programming languages. I can't understand how anyone can understand its weird addressing modes.
    edited 2010-05-19 03:24
    Ahle2 said...
    Perhaps, yes, though I suspect the memory handler that dispatches on reads from the frame buffer range. Unfortunately I'm rather drunk now and even worse is that I ran out of coffee, so no chance to fix it tonight :/
    edited 2010-05-19 03:48
    Now the 2650 I never really programmed in assembler, no no no, that wasn't good enough or maybe it was just too expensive. Good ol' machine code in hex, that's what I remember. Most programs were small so the program page thing never became a problem but the indirect bit was a very useful feature as was the auto inc/dec indexing modes. What's weird about that? (or with Forth).
    The 2650 could be clocked all the way down to DC which was a notable feature at the time. At the time the local electronics store "TechniParts" IIRC sold them for $26.50 which was also quite cheap, nothing like the 32-bit ARM chips now with internal memory for $1 (in 2010 $) though.
    *Peter*
  • TonyDTonyD Posts: 210
    edited 2010-05-19 08:45
    pullmoll said...
    The Elektor_TV_Games_Computer (Signetics 2650A) was from 1979 and the Elektor Junior (6502) was published from 1980 onwards. There was an Elektor SC/MP computer as well, published in 1978. Glory Days smile.gif
    - Tony
    http://zuzebox.wordpress.com/
    edited 2010-05-19 10:08
    I quite liked the SC/MP chip, it had a shift register which made serial comms very easy. The instruction set was rather limited, though.
    Leon Heller
    edited 2010-05-19 10:43
    TonyD said...
    Hmm.. perhaps it was the Junior Computer, while I thought it was an even earlier video game system without a CPU. Some years ago I still had the issue where it was described.
    I wrote an 2637 video driver for an Arcadia emulation in C some time ago. Fun stuff.. The Arcadia could probably be "propelled".
    edited 2010-05-19 13:57
    pullmoll said...
    There was, it was a TV Tennis game from 1975 made using 555's and other discrete components. There were a couple of updates published for it over the years. Elektor also published a TV Game (1977) based on the popular AY-3-8500 chip. The AY-3-8500 was found in many of the dedicated Pong and Tennis consoles of the time such as the Coleco Telstar and Magnavox Odyssey.
    - Tony
    edited 2010-05-19 14:36
    Where the circuit was the game. I loved those, and for years kept a size "D" hand drawn "Pong" schematic on my wall. Lost it in a move and am still kind of pissed about it. All the gates, triggers, counters... and the neat annotations from the engineer were cool too. People with good vision and some ability to communicate it are always intriguing to me.
    I just read about this machine, and got an answer to something that has bothered me. On some computers, other devices like graphics chips can access the memory without interrupting the CPU. This was true on Apple and CoCo, for example, but not true on C64 / Atari. I never did hear a solid explanation for why that is the case, when it's clear those devices can operate, leaving the CPU at full speed. Atari and C64 machines are slowed considerably when the user requests the more advanced graphics features. Was this cost of RAM, or something else?
    Anyway, this is kind of a cool old computer, and I'm excited to see a 6502 build up.
    8x8 color 80 Column NTSC Text Object
    edited 2010-05-19 19:34
    When I was building up my Nascom, 4KB of SRAM chips was two weeks wages. The choise of chips for the Nascom2 (4118,s I think) caused the company to go bust when they went scarce and they had to give away 16KB expantion boards instead.
    edited 2010-05-20 11:01
    I think by cost potatohead meant the expense of time or CPU cycles it takes to have more complicated graphics.
    I can only speak for the Atari 800 and its ANTIC chip (and GTIA). They also used the 6502 clock state where the CPU puts nothing on the address or data bus to fetch the video RAM data. Writing to the video RAM or display list was thus asynchronous to the ANTIC fetching the same data and could be flicker-free.
    The Colour Genie OTOH had Z80 wait states inserted by the CRTC accessing memory, so it would become a little slower if you increased the number of characters per line. The character generator RAM was not synchronized, so writing it caused flicker (tiny white dots) spread across the display, which was a major refutation for animated graphics.
    edited 2010-05-20 18:23
    Ah the delights of the "Snow". There were a couple of attemps to hide it, on the favourite Z80 computer of mine, in the end they just replaced the white snow with black snow, so it didn't show up as much (in their oppinion)
    edited 2010-05-20 21:22
    The keyboard is working now - with the (almost) default Keyboard.spin code. The Microtan had an ASCII keyboard, so I can use the standard object.
    The wrong data in the 2nd screen half during the initial scroll is still there and I couldn't find out where it comes from. It's not the data returned by the io.spin code.
    When entering commands, the TANBUG always only prints a ? after the command, which probably means it didn't understand the command.
    The commands from the Wikipedia Tanbug page seem to work. The hex dump is exceptionally slow.
    Post Edited (pullmoll) : 5/22/2010 3:19:15 PM GMT
    edited 2010-05-22 15:10
    I can't the heck find a bug in the 6502 emulation.
    Either the LDA abs16,X ($BD LL HH) or the STA abs16,X ($9D LL HH) opcodes are wrong, yet they are so simple.
    The sequence of subroutines (vector) for the first is
    rd_abx_p = read absolute plus X, with page wrap adjustment, into alu
         stores X in XY
         calls calc_abs_xy_p which reads the opcode word at PC, adds X and allows the result to be in the next page
         calls rd_byte to read to alu
    m_lda = store alu in A and set N and Z flags accordingly
    The second opcode is handled by
    m_sta = store A in tmp
    wr_abx_np = store tmp in absolute plus X, no page wrap adjustment
        stores X in XY
        calls calc_abs_xy_np which reads the opcode word at PC and adds X to the lower byte only (page wrap)
        copies tmp to alu
        calls wr_byte to write from alu
    Somewhere along the code execution alu is damaged (set to $00), but only for the 2nd half of the screen memory ($300..$3ff), which is very odd in itself, since there is just one handler doing both.
    I verified that reading $300 to $3ff through the I/O handler actually returns the screen memory contents and not $00, so I assume that either A is destroyed by fetching the next opcode, or that the store does it under certain circumstances. Also writing to the screen using the io_command and io.spin handler works as expected.
    I posted it on the previous page already: the code that causes the bug to manifest itself:
    0000FA40: E8                 inx
    0000FA49: E8                 inx
    0000FA56: A8                 tay
    0000FA57: 88                 dey
    0000FA5C: 60                 rts
    The opcodes at $FA43 and $FA46 are the ones that fail.
    The almost identical loop, except for the abs16 values, at $FA3A does work. What the heck can cause a bug dependency on an absolute address?
    Anyone willing to take a look at my code?
    Could I trace this kind of code with one of the Spin/PASM debuggers?
    Post Edited (pullmoll) : 5/22/2010 3:31:44 PM GMT
  • ChasChas Posts: 5
    edited 2010-05-22 23:17
    Quote from above: from Pullmoll
    Yep, that was one of Aaron's goals: a universal disassembler. I used it to disassemble the Microtan code fragment. It has an impressive list of supported CPUs: including TMS1000
    Who can tell me who has accessed the TMS1000 to dump the code and use disassembler ?
    I am looking at a TMS1000 in a Hornby Zero One train controller that used the TMS1000 in the 1980's. Would like to update with some minor changes onto a new processor.
    Comments welcome
    Charlie
    edited 2010-05-23 16:57
    Chas said...
    I don't know if this has happened. According to the author of the tms1000 CPU core it is incomplete and not very well tested. It was capable of running a calculator example code from some technical manual, though.
    Chas said...
    I have no idea of the requirements to do this, sorry.
    Juergen
