Robot Control Board MSR1 Fatal Design Flaw
John Abshier
I was going to use the MSR1 for a robot designed for the Home Brew Robotics Club tabletop competition.· For motors I am going to use the· Faulhaber gear motor and its HES164A encoder.· Using the attached program I got all zeros for encoder reading and delta encoder reading.· I then wired the motor up to a Professional Development Board and everything worked as expected.· Looking at the datasheet for the level translators I found:
The TXB0108 is designed to drive capacitive loads of up to 70 pF. The output drivers of the TXB0108 have low
dc drive strength. If pullup or pulldown resistors are connected externally to the data I/Os, their values must be
kept higher than 50 kΩ to ensure that they do not contend with the output drivers of the TXB0108.
For the same reason, the TXB0108 should not be used in applications such as I2C or 1-Wire where an
open-drain driver is connected on the bidirectional data I/O. For these applications, use a device from the TI
TXS01xx series of level translators.
I guess I will solder up a motor driver on a Protoboard.
John Abshier
John Abshier
John Abshier
I don't think it is even a flaw. I'd rather save the Prop. More advanced users can easily fix this and I am going to add the translator by-pass pins per the Stingray Documentation (as Mike mentioned) for jumpers when I get the chance. I just didn't want to do it when the board was brand new.
I will probably use "red" jumpers to get my attention and I have also been thinking of getting something to put over the I/O pins (maybe some anti-static foam or empy 3 pin connectors or jumpers down the ground pins) to remind me when I have the translators disabled - Just so I don't accidentally forget and fry my Prop. I could also just disable just the P16 to P22 group (and keep it disabled to avoid confussion)
Any other ideas for this? I just want to make it as fool-safe as possible. As the old saying goes though - "It is hard to make anything fool-proof, because fools are so ingenius."
Whit+
Post Edited (Whit) : 5/23/2010 2:14:39 AM GMT
