Hint on Finding Small Parts that "Dropped"
(or how to avoid an unending stream of undesirable words from spewing forth)
Who has not dropped something like a #2 lock washer, or sub micron surface mount resistor? If you are someone who hasn't, move on, nothing more to see here.
For the other 99.99% of us, here's what I hope is a helpful hint.
If you work on a carpeted floor, so sorry, but you're screwed (pun intended). The best I can offer is a freshly emptied and cleaned "dust buster" or other hand held vac.
For those of us smart enough to be working on a smooth floor, here's how you find those tiny parts (only works for 3-d parts).
* Get a flashlight
* Move big stuff out of the way (chairs, dogs, etc.)
* Turn out the room lights (yes, we're going to work in the dark)
* Get down on your hands and knees, or even your belly (see note 2 below)
* Turn on the flashlight, and hold it so that the edge of the flashlight is on the floor, and the beam is parallel to the floor.
** What you're after is in essence to light up the floor from the side
** Slowly sweep the light from side to side
* The part can be found (usually) by looking for it's shadow.
Note 1: I thought to post this because of this tread over in robotics: http://forums.parallax.com/showthread.php?p=908927
Note 2: Based on what I saw at UPEC, most of us (self included) would be closer to the floor on hands and knees than if we laid on our bellies
John R.
Click here to see my Nomad Build Log
* Get a flashlight
John R.
Have you ever seen some of those parts under the microscope after you have picked them up? Depending where they have landed they can have bits of dust and pet fur on them, even off a clean floor. I assume you are mostly talking about SMD parts so in which case I avoid reusing them.
*Peter*
I also learned the flashlight thing while working on plastic models. If you dropped a piece, you couldn't go to the bin and find a replacement, and I really didn't like the idea of having to repurchase a kit for one part. Plastic is not magnetic...
Also, the magnets are good if you know about where the piece is, but not if you don't have a clue. The shadow thing helps you find them.
I really like the idea of a fine mesh on the vacuum hose. A lot easier than digging through the pleats of the filter.
John R.
Good idea. It works for acoustics, too. See side-scan sonar.
www.instituteformarineacoustics.org/SonarPrimer/SideScanSonar.htm#Shadows
*Peter*
