5MHz Crystal 20 pF, HC-49/µ
Hi
If I don't use this line in my program. = (con _clkmode = xtal1 + pll16x_xinfreq = 0_500_000)
Could I take out my 5MHz Crystal 20 pF, HC-49/μ (as in not use it, at all).
So if I can take it out and not use it,
Do I need to put pin[noparse][[/noparse]X0] and [noparse][[/noparse]XI] to ground or hook 3v up to them
or just leave them be, that's what I am hoping for.
con _clkmode = xtal1 + pll16x _xinfreq = 0_500_000 pub Kid repeat if ina [noparse][[/noparse]23] == 1 right pub right dira[noparse][[/noparse]0..19] := %11111111111111111111 outa[noparse][[/noparse]0..19] := %00000000000000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000000000000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %10000000000000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %11000000000000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %11100000000000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %11110000000000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %11111000000000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %11111100000000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %11111110000000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %11111111000000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %11111111100000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %11111111110000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %11111111111000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %11111111111100000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %11111111111110000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %11111111111111000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %11111111111111100000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %11111111111111110000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %11111111111111111000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %11111111111111111100 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %11111111111111111110 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %11111111111111111111 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000000000000000000
Many modern microcontrollers have flexible clocking options and even on-board clocks that can be selected but they all need a clock that regulates all sequences within a CPU etc. The Propeller does indeed have an on-board clock but you should RTM before seeking further advice.
*Peter*
Crystal Output. Provides feedback for an external crystal, or may be ((((left disconnected depending on CLK Register settings))). (((No external resistors or capacitors are required))).
Thank you for your help Peter Jakacki
Why do you want to run it without one?
Some questions I can answer but the best answers are ones that you are helped to find yourself. Your questions indicates you need to do some research and so I have helped you at this stage so that we can be ready to answer IF you still have a question after that.
*Peter*
it should be
pll16x_xinfreq = 5_000_000
I always have someone watching my back.
And I think You need reread Data sheet again. It is not possible - But some IC's have XO as Internal XTal output but not Propeller.
Regards.
Ps. On Propeller You can only use XI as external frequency input.
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
Re-read the manual.
Jeff2,
The built-in RC clocks can be used (RCSLOW / RCFAST) instead of an external crystal or resonator. What's not obvious from the manual is that these clocks are not accurate. The actual frequency of both of these vary a lot from chip to chip and also vary somewhat with ambient temperature and a little with chip supply voltage. Since the system clock is the time and frequency standard for everything, you can't use the built-in clocks for serial I/O or video or anything else requiring precise timing. The Propeller's boot loader gets around this by using the RCFAST clock and requiring that the data from the PC be "self-clocking" rather than ordinary asynchronous serial format.
If you're using RCSLOW or RCFAST, you can just leave Xin and Xout unconnected. As a general rule, it's always best for low power consumption to connect unused input pins through a resistor (like 10K or 47K) to ground (Vss) or the supply voltage (Vdd).
