Gerber to CNC Conversion Software
Hi All;
I'm building a general purpose XYZ tabletop machine·for the purposes of light duty CNC machining. The first application is PCB drilling, PCB 'carving' and·board routing. I also plan to make attachments for·pick 'n place assembly, glue and solder paste·dispensing·as well as·3D plastics·"printing".
I'm at the point where I wish to try my hand at the first job, and need a Gerber to CAM conversion program to trace out the tool path for·the cutter to isolate the PC board traces. Searching the web, there seem to be a myriad of choices from mulitudes of sites..... somewhat overwhelming.
My question is, can anyone reccommend a particular low cost (free trial) package to do this conversion, as I do not relish the process of downloading dozens to ferret out an appropriate one if this has already been researched by this forum's members.
Many thanks,
Peter (pjv)
Many thanks,
Peter (pjv)
No, I dont use Eagle.... Protel is the layout package we use. And in any case as a standard, I'd like to import anyone's standard Gerber files.
Also, I forgot to mention, I'd also like to import standard Windows bitmap files for conversion to CNC G-codes.
Cheers,
Peter (pjv)
Leon Heller
Amateur radio callsign: G1HSM
Lots of propeller based products in stock at affordable prices.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
Thanks for that tip. I downloaded the tutorial, and it looks quite impressive for a low cost product. Its hard to say how it compares to Protel, but it feels like the learning curve is smaller.
Anyhow my application is not for the layout package, but for its G code generation capability. From the tutorial I could not determine if I could import Protel Gerbers into it, for "fiddel free" generation of G codes. I did note that the G code generator is a seperate packge (ACE I think) from them. I should load that up.... perhaps there are more details.
Cheers,
Peter (pjv)
