PropBasic users - PropBasic vs Spin?
So now that PropBasic has been out a while and its capabilities have been expanding, I'd like to know how some experienced PropBasic users feel about the compiler vs Spin.
My quickie take is:
- PropBasic has the advantage of being fast.
- Spin has the advantages of size and the OBEX.
Are there any other significant advantages one has over the other?
Is there anything you can do in Spin that you can't do in PropBasic (or vice versa.)
My quickie take is:
http://forums.parallax.com/forums/default.aspx?f=25&m=434987
Ray
Thanks for the link. As often as I check this board, I can't believe I missed that one!
So it seems that I just asked almost exactly the same thing as Maxwin. Sorry...
I working on a rather large program that has quite a few subs.· What I found to be a drawback of Propbasic is that it is compiled to run in one cog.· therefore code space very quickly becomes a problem for large programs.· I tried and found I had to make most of my subs into tasks.· I have programmed for the BS2P40 and the Basic is nice.
I personaly am sticking with spin as my choice of language.· The Obex is a blessing for us not to hot assembly programers.
Ben
Use LMM mode. "PROGRAM Start LMM".
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
There are two rules in life:
· 1) Never divulge all information
If you choose not to decide, you still have made a choice. [noparse][[/noparse]RUSH - Freewill]
At some point, perhaps, there will be an exchange area for PropBASIC libraries. That said, it will bring the same problems as ObEx: convenience at the risk of bad code.
In then, PropBASIC, Spin, and PASM are tools -- learn what you can to give yourself as much flexibility as possible.
Jon McPhalen
Hollywood, CA
Post Edited (JonnyMac) : 5/19/2010 10:44:46 PM GMT
I am very thankful to have PropBASIC! Having started in PBasic the move to Spin was a struggle for me. PropBASIC has allowed me to work in a familiar language and enabled me to move forward in my robotic pursuits by being able to switch to the Propeller chip. Also, Bean, Brad(BST IDE) and others have been available and more than willing to help. I think you should take a good look at PropBASIC
Here is links to two of my robots http://forums.parallax.com/showthread.php?p=876789 and http://forums.parallax.com/showthread.php?p=894042
Just to give context to my statements, I am not a professional programmer or engineer and would consider myself an advanced beginner with programming the Propeller chip. Also, I still study and continue to learn and stay familiar with Spin because it is Parallax's language and many resources are written in it.
Tony
Ray
I have read about LMM however, has any speed comparisons been made between LMM Probasic and Spin?· I know that in LMM the cog has to wait for its turn in hub ram.· Another thing·any of the examples for tasks in the documentation have been for tasks written in Propbasic.· How do you call a Assembly routine as a task?· Probably obvious but now obvious to me.
Thanks for the reply
Ben
So does SPIN.
"Are you suggesting coconuts migrate?"
And, thanks to Brad, I can do the whole works, PropBASIC and Spin, in BST.
Jon McPhalen
Hollywood, CA
