MCP3208 ADC circuit to test 12v battery.
I'm using a MCP3208 ADC to read some Srarp IR sensors. I thought that since I will have a few extra inputs that it would be nice to be able to measure the charge of the batteries.
could someone point me to a circuit that I could use to proportionately drop the voltage within the limit of this ADC? my Max voltage is set to 5v.
DGSwaner
"When in doubt, use C4" - Jamie Hyneman, Myth Buster
DGSwaner
there are a lot of webpages "trying" to explain electronics. My personal oppinion about most of them: they are Smile for beginners.
This one seems to be quite good:
Lessons In Electric Circuits -- Volume I DIVIDER CIRCUITS AND KIRCHHOFF'S LAWS
especially the attached picture shows what Timmore meant with two resistors.
best regards
Stefan
Or you could put two 10k resistors in parallel to get 5k above.
DGSwaner
