Need someone to test my EmicTTS module driver please!
Hello all,
I've just finished building an Emic driver object for the Propeller, and I'd like some volunteers to possibly try it out on your own Emic, and give some feedback. You know, like ease of use, program size, etc. I've tested it on my setup, but I want to make sure it'll work cross-platform, too.
I have the basic version on the obex here: http://obex.parallax.com/objects/605/
I still have some testing to do before I upload the Extended version of the driver, but this one covers everything necessary [noparse]:)[/noparse]
Thanks for your help!
- Robofreak
Austin Bowen,
"One must watch out for mechanics. They start out with a sewing machine, and end up with the atomic bomb" - A quote from someone that I saw on Addall.com
"Not only do I see the glass as half empty, I wonder if anyone poisoned the glass with arsenic" - My dad, inside joke haha
- Robofreak
Austin Bowen,
cheers ... BBR
cheers ... brian riley, n1bq, underhill center, vermont
The Shoppe at Wulfden
www.wulfden.org/TheShoppe/
www.wulfden.org/TheShoppe/prop/ - Propeller Products
www.wulfden.org/TheShoppe/k107/ - Serial LCD Display Gear
Post Edited (Brian Riley) : 5/18/2010 10:23:32 PM GMT
Austin Bowen,
Austin Bowen,
{{ File: EmicTTSDriverDemo.spin This program assumes that both switches on the module are in the OFF position, for hexadecimal communication (faster) and no received echo on the Emic's TX pin. The system clock must be => 20MHz (If my calculations are correct.) { stuff deleted } }} OBJ: EMIC : "EmicDriver" CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000HUH?????
cheers ... BBR
All the timing is calibrated off of the clock's speed, so it *should* work at a slower speed than the usual 80MHz. I'ma try it now that you brought it up haha
- Robofreak
Austin Bowen,
Austin Bowen,
Thanks!
- Austin
Austin Bowen,
