Ping h2o
Is there any info as to when we can expect the PING H2O weatherproof sensor to hit the streets? It was featured in the Parallax 2010 calender but here we are almost half way through the year and it seems to have vanished. I am trying to record river heights with an ordinary ping, and although the sensor is well shielded from direct rain, it does not like misty mornings or the humidity associated with heavy rain. Needless to say, when it is raining is when the river is likely to rise, so my current situation is distinctly sub-optimal.
Thanks in advance,
Nick
Thanks in advance,
Nick
Parallax ran into engineering problems with the Ping H2O. They may not be making them at all is the last I heard on it.
Shawn Lowe
When all else fails.....procrastinate!
I have tried covering bits of mine with liquid electrical tape, but I'm guessing there is something humidity sensitive where I did not dare go, ie close to the transducers.
Nick
The simplest is a capacitive sensor consisting of 2 parallel conductive strips or a 1/2 inch copper pipe inserted in a 3/4 inch pipe. Both setups need spacers to hold things in place without blocking water access, but that is relatively simple. Add a resistor and measure the RC time constant to read water height. The only difficulty may be sediment fouling, but there are ways to avoid that.
The float from a new style toilet filler (float goes around inlet pipe) and a PVC pipe for a post might also work. Magnetic reed switches, optical encoder, multiturn pot, or a combination of reed switch and encoder could be used. More complicated than the capacitive approach or what you have now, but it has been proven in use.
Nick
1) the need to calibrate (but I could use the PING on a dry day)
2) whether the capacitance changes according to sediment in the water
3) whether I need to periodically reverse the current to prevent electrolysis
In some seasons my river will actually deposit calcium on leaves on low hanging branches, so I am wary of changing chemistry in the water.
Nick
http://www.parallax.com/Store/Sensors/PressureFlexRPM/tabid/177/CategoryID/52/List/0/SortField/0/Level/a/ProductID/590/Default.aspx
Shawn Lowe
Many thanks once again,
Nick
You might want to contact the manufacturer of the sensors Shawn pointed out. I have not talked with them, but their web site talks about other lenghts, and somewhere even mentioned "continuous tape" to "cut your own length.
John R.
Click here to see my Nomad Build Log
maxbotix.com/MB7060__XL-MaxSonar-WR1.html
Tracy Allen
www.emesystems.com
The Ping H2O project is still lurking in the background of my to-do list. The project is not dead and I do plan on reviving it here in the very near future. A complete redesign is required and the newer version promises to be very exciting. I will give more details as the project progresses.
Thomas
Nick
Shawn Lowe
