Mini graphic LCD 128x64 for $5.99 + ($3.99 shipping)
Hello Forum,
Here is·the 128x64 Mini graphic LCD, that I have ordered·a few days ago.
The contorller ICs are the same as·his biger brother has (KS0107-KS0108)
I think that is a very fine price and I·hope the·quality is fine·too.
I·would·post about the quality,·when I·got the LCD module.
http://www.satistronics.com/./
B0-DB7: Data Pins
CS1 – CS2: Chip Select
RST: Reset GLCD
E: Enable
R/W: Read-Write Selection
RS: Register Select
If you want a 128x64 graphic LCD that only uses 2 I/O then I will be making them available at a very good price very soon. I am still in the throes of setting up my website to handle shopping carts and PayPal etc.
*Peter*
but no go on these???
Serial graphic 128x64 controller-in two versions,serial UART(VT100) and I2C
I have got the serial UART(VT100) but I have not try it yet.There is another serial backpach for 128x64 graphic LCD at Sparkfun where you could also download:
source code, schematic, datasheet and make one your self, you need only one ATmega168 chip.
Sparkfun,graphic backpack: http://www.sparkfun.com/commerce/product_info.php?products_id=9352
the highest voltage on the pins has been 3.9 so I guess to be safe you can do it ..
PS. I am also a hobby guy like you, and I'm Not a worlds ahead of you, maybe the other way ;- )
Regards
R.D
