position control of continuous rotation servo? — Parallax Forums
myk1323myk1323 Posts: 7
edited 2010-05-18 20:18 in Robotics
Hi, as I understand it a continuous ratation servo has the pot. disabled, basicly making it act just like a geared motor. Is it possible to still have position control with a continous rotation servo ...like say for instance i want exactly 2 and 1/2 rotations? Can it be accomplished simply through on/off timing ...say a signal for exactly 25 seconds, would that produce the same result every time? how much of an error would there be? thanks very much if you can aswer any of this!!! freaked.gif
    edited 2010-05-18 02:37
    No. What you're describing is known as "open loop" control and will not produce accurate results. For accurate positioning/turns count, you need a feedback mechanism, such as an encoder.
  • W9GFOW9GFO Posts: 4,010
    edited 2010-05-18 03:02
    If you only need two or three rotations you might be able to use a sail winch servo. They can make a couple rotations in each direction before hitting the stops.
    Or you could use a simple feedback mechanism like a snap switch which engages notches around a disk - like this;
    Rich H
    The Simple Servo Tester, a kit from Gadget Gangster.
    edited 2010-05-18 20:01
    Similar to what W9GFO illustrated, A Geneva mechanism could also be applicable here if you always wanted to move at a specific division of the full amount of rotation.
    en.wikipedia.org/wiki/Geneva_drive
    Beau Schwabe
    IC Layout Engineer
    edited 2010-05-18 20:12
    Or as someone suggested in a different·thread, use·a standard·servo to drive a step-up geartrain. You can overdrive the servo with Stamp-produced pulse widths to get nearly 180 degrees of travel. So if you drove a 6:1 step up geartrain, you could get approximately 2.5 full rotations, but you would have hardly any torque. You would have reasonable positioning accuracy anywhere in that range, at about 1/6 the resolution of the servo.
  • myk1323myk1323 Posts: 7
    thank you for your help!
