32-bit averaging help
Any of you mathematicians know a way to average a bunch (20 to 100 -- the number is flexible at this point if there is some limitation) of 32-bit values without resorting to float math? The desire not to use float math is purely for the purpose of speed, so if the integer math method is slower than the float math, that won't work.
The two methods my feeble brain came up with won't work:
The normal add and divide method will likely overflow with the numbers I am using.
The other option of divide then add is also not practical as I will loose way too much precision.
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Some of my objects:
MCP3X0X ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library - Don't allow strings to be the bane of the Propeller, bend them to your will!
Fast Inter-Propeller Comm - Fast communication between two propellers (1.37MB/s @100MHz)!
Some of my objects:
What is your input value range ? In other words do the input values use ALL of the 32 bits ?
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
There are two rules in life:
· 1) Never divulge all information
If you choose not to decide, you still have made a choice. [noparse][[/noparse]RUSH - Freewill]
I don't know the details of your values...but if no two values will ever exceed a 32-bit value then you can do a running average always averaging the previous result with the next value by adding and dividing. This also works good if the values aren't stored, but coming in steadily. You save memory if you only need the average.
Chris Savage
Parallax Engineering
Some of my objects:
Some of my objects:
Jonathan
lonesock
Piranha are people too.
Some of my objects:
CON ShiftVal = 6 PUB t | i, sumLo, sumHi sumLo~ sumHi~ repeat i from |<30-63 to |<30 sumLo += i & $FFFF sumHi += i >> 16 sumLo += constant( |<(ShiftVal - 1) ) ' for rounding sumLo >>= ShiftVal ' divide the low accumulator sumLo += sumHi << constant( 16 - ShiftVal ) ' divide the high accumulator and shift back into pos in 1 step ' sumLo now has the average valueJonathan
lonesock
Jonathan
lonesock
Some of my objects:
If you have 20..100 values where each value can be up to 31 bits, you will definitely need a 64 bit accumulation. I'd suggest to use a power of 2 number of values, like 64, and then pre-scale the addends. I would do it in PASM, as it is easier and, of course, faster to do 64 bit math there.
VAR long params[noparse][[/noparse] 2] long avg32 long cog PUB start(table_addr) params[noparse][[/noparse] 0] := table_addr params[noparse][[/noparse] 1] := @avg32 cog := COGNEW(@entry, @params) return cog => 0 PUB average avg32 := -1 repeat while avg32 == -1 return avg32 DAT org 0 entry mov t1, par ' get address of parameters rdlong table_ptr, t1 ' get first parameter : table address add t1, #4 rdlong result_ptr, t1 ' get second parameter : result address :wait rdlong t1, result_ptr ' get result value cmp t1, minus1 wz ' is it -1? if_nz jmp #:wait ' no, wait mov count, #64 ' average 64 values mov accu, #0 ' clear 64 bit accu mov accu + 1, #0 :loop rdlong value, table_ptr ' read 32 bit value add table_ptr, #4 ' next address mov value + 1, value ' value to less significant long also shr value, #6 ' more significant 26 bits in #25..0 shl value + 1, #32 - 6 ' less significant 6 bits in #31..26 add accu + 1, value + 1 ' add low addx accu, value ' add high with carry djnz count, #:loop sub table_ptr, #4*64 ' back off table pointer wrlong accu, result_ptr ' write the result jmp #:wait table_ptr long 0-0 ' pointer to 64 longs to average result_ptr long 0-0 ' pointer to result long count long 0 ' counter value accu long 0, 0 ' 64 bit accumulator value long 0, 0 ' 64 bit value t1 long 0 minus1 long -1The table can be a round-robin list where your new value automatically overwrites the oldest from the list.
If you want to use another table size, you would have to adjust the #6 and #32-6 accordingly (e.g. 7 for 128 values, 8 for 256 and so on).
If your values are signed longs, you would have to change the shr into an sar.
Pullmoll's Propeller Projects
Post Edited (pullmoll) : 5/14/2010 11:02:10 PM GMT
Some of my objects:
