Mlx90614esf-daa
i want to use this sensor on the Mlx90614 module by replacing the MLX90614A sensor...
but the operating voltage of this is 3V..
can it tolerate 5V..
because Mlx90614 module uses 5V..
What are you connecting the sensor to? If its the propeller, I have connected the sensor the DAA version directly to the propeller without the module since both the propeller and DAA run at 3.3V.
