Spectrum Emulator ( now with SNA file selector )
Baggers
Hi All,
Here is my Spectrum Emulator ( well I guess it's more a culmination of a lot of peoples work. Chip for his original TV and VGA drivers and his prop of course lol, pullmoll for his mods to chips VGA driver, to do one attribute per character, and now my own mods to make it a 256x192 bitmap driver, and of course pullmoll's Z80 emu.·)
Cheers,
Baggers.
Edit:
V1.0 : ·Added Source for Spectrum emu, and removed old spec vga driver source [noparse]:)[/noparse]
V1.1 file = speccy-bst-archive-100529-153523.zip
V1.1 :· Added SNA file selector, which also shows a screenshot of game highlighted [noparse]:)[/noparse]
··········Press esc to select new game, be careful you can't continue with the current game once you press esc, it's gone, until I put a continue in.
········· I've also had to move IO.spin into Speccy.spin, because I couldn't talk to QZ80 from IO.
V1.2 file = speccy-bst-archive-100529-185161.zip
V1.2 :· Added new fatfs.spin, also freeing up a cog, due to fatfs now having XMM included.
V1.3 file = speccy-bst-archive-100531-181012.zip
V1.3 :· IO is now handled in PASM, and I've fixed a some start ups, so more games now work [noparse]:)[/noparse] including the ZX81 emulator that Giemme posted.
http://www.youtube.com/watch?v=TB5INqBrUYs
Post Edited (Baggers) : 5/31/2010 5:21:06 PM GMT
Cheers,
Baggers.
Edit:
I am making up a "DracBlade" board with two selectable EEPROMs, for Nas and CPM, and you come up with a third option.
It will go ino my "replacement Nascom" which has been a 8052 MCS, AVR644 ChipBsaic2 and a few others before. I am going to have to make it dependant on the SD card if I am to make it truly flexible.
Hey-Ho.
Style and grace : Nil point
The CP/M emulation is no longer just CP/M. It is now evolving into emulating multiple computers. I've been thinking along the same lines as Toby. I put a NASCOM on the board, then wiped the eeprom and put a CP/M computer on the board. Thanks to pullmoll's code, the sd card stayed the same. Indeed, I still have all the boot data for both emulations on the sd card. There is lots of room, and as the number of emulations increases, one could imagine a single SD card image that can do everything.
So - to the eeprom. 32k per emulation, so two is the max you can fit on an eeprom. Is it possible to put all the emulation code on the sd card? For flexibility, you want almost identical code, for debugging etc. So I wonder, what is the absolute minimalist code needed to boot up a propeller and give you a menu choice to select which 32k hub ram image to load?
sd card driver
keyboard
display
This is a mini operating system ? sphinx
You select 'NASCOM'.
Then all cogs stop working except one that loads 32k of data off an sd card and into hub ram. Then it jumps to the beginning of the code and starts running it, which then overwrites the cog that loaded it etc. Possible??
This probably is going off on a tangent. Getting a spectrum working sounds fun. Are you going to use all the clever code in qZ80?
A spectrum = games, right?
This gives you an operating system where you can do dir etc and can run any emulation. So all emulations can be on the same SD. This is what I believed was required.
Sphinx or propdos doesn't really matter for this problem - all you really need is a way of loading up binary data off the sd card. Then Toby can have all the emulations on one sd card (and only need a 32k eeprom)
Ok, thinking out loud. Let's say I have propdos on my eeprom and it boots into that and gives you a menu of which computer emulation you want to run. Pullmoll issues a new version of aZ80. I do a quick test with an F10 download to ram and it works fine. So, now, do I compile that to a binary and then pop out the sd card, put it in my USB reader and copy that binary onto the sd card?
If so, that would be pretty easy to do.
I like the idea of a micro sd card being many computers. It is a CP/M computer. A NASCOM. A Spectrum. You choose when you boot it up.
Post Edited (Dr_Acula) : 5/10/2010 3:19:22 AM GMT
It is all descrived on the RamBlade thread with the source code. SO it should be easy for everyone to use and that way we keep it all standard. For ZiCog, I just copy a new binary to the sd card and it runs! So as soon as I have SphinxOS working correctly, we can just copy that and rename it to BootProp.bin and we will have substituted PropDos with SPhinxOS. No other changes needed.
To expand on this, I want to build the SphinxOS get & put commands to do FTF from the pc via serial. Same could apply to standalone xmodem/ymodem etc. Get, Put, xmodem, ymodem should all be Sphinx aware programs and then we can release binaries which do not care about the hardware or drivers. This is my aim anyway.
Dr_Acula, yes, I'm going to use all the clever code in qz80, and modify it to work a spectrum, and yes, a spectrum will mean many games [noparse]:D[/noparse] as for the emulation speed, I'm not sure yet, how fast it'll be, so although it'll work, it may not play games very well, speed wise.
on a side note, once we have faster prop ( Next year ) it will run a LOT faster than it currently does, not to mention the fact that it's internal Hub-RAM will be big enough to store the 128KB for the bigger games also, and not need the external SRAM so will be faster again [noparse]:D[/noparse]
Pullmoll says it is going to be tricky to get CP/M plus VGA to fit. Though he has got a NASCOM to fit and there is still the leftover hub ram from loading cogs. So lots of potential there to concatenate cogs, load them as cogjects off an sd card, or have a VGA driver that reads ram from different locations.
But - for games, maybe you could save some code? For starters, maybe you don't need the UART code?
What other bits do you need to get a spectrum working?
Post Edited (Dr_Acula) : 5/10/2010 8:35:49 AM GMT
yes, I'll be removing lots of unwanted code [noparse]:)[/noparse] I'll be keeping the SD for loading games [noparse]:)[/noparse] and the qz80 obviously, I have my display driver, I'll be changing all the IO handler code, so hopefully should save some there too, so should be able to fit in the 6.75K for screen.
I just to give you an update [noparse]:)[/noparse]
I have the VGA screen driver working ( attributes, bright, flash etc. )
I've put in the The Spectrum Rom, and it now gets to the now immortal words "(C) 1982 Sinclair Research Ltd" [noparse]:D[/noparse] so Happy days there.
Next is to get the IO ports working for the keyboard, and we're away, and add some code to have game files loading. [noparse]:)[/noparse]
Once it's all working with keyboard input etc, I'll update with source, video and pic [noparse]:)[/noparse]
Come on... I want to see a picture! Now!
Pullmoll's Propeller Projects
Time to draw up a nostalgic games list to try
It shouldn't be any hard at all compared to the much more advanced SID-chip.
Maybe we could even have better than CD quality sample playback thanks to the simplicity of the chip. (SIDcog is "only" 31Khz)
Probably it wouldn't take more than a few hours to have a decent emulation of it.
This will be my next thing on my "Propeller ToDo list".
However, I do not have much "propeller time" at the moment.
nyje, thanks roll on nostalga times!
Toby lol, yeah, that would be interesting [noparse]:D[/noparse]
Ahle2, No rush, as I'm getting the 48K Spectrum working first ;D
That may have been ok for the youth, of the day, but now the arthritis is kicking in ....
Post Edited (Toby Seckshund) : 5/13/2010 9:23:41 PM GMT
Dr_Acula, not sure yet, will see once I get the last bits sorted, and can load a game [noparse]:D[/noparse] then they should flood through [noparse]:D[/noparse]
To wet your appetite, here's a quick video demo [noparse]:D[/noparse]
http://www.youtube.com/watch?v=5thytZ_Xem8
Not had chance to do any more on it today though, as I've been taking my kids to their friends party,
I won't be able to do any tomorrow either, as I'm going to a Retro Computer Museum ( Retro Gaming Event ).
Currently it runs about 1/4 of the speed of a spectrum, but I think that's down to the IO in spin, I'll convert that to PASM which should speed it up a tad [noparse]:D[/noparse]
once I've got that done in PASM, it's then down to adding a LOAD and SAVE program from and to SD, and we're sorted!
Baggers.
I now have it (hardwired)loading a .SNA file and running Manic Miner [noparse];)[/noparse] there are some issues with other games, but Manic Miner seems to work fine, I think there's some issues with interrupts, which I'm still looking into.
It's late, and I'm up early tomorrow, so I'll post pics and source so far ( for DracBlade )
Baggers
OBC
Are you Propeller Powered?
Propeller Feature Projects: PropellerPowered.com
Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
http://www.youtube.com/watch?v=qPqTGPTfILE
It's no way near being "postable tbh" and it's all in one directory, due to archiving, and using it, but it's working enough to share the goodness, til it's tidy and working with more games.
(This means there is hope for a C= emulator one day. [noparse]:)[/noparse]
Any chance that some commands could be added to the BASIC for some I/O control?
This could make an interesting alternative to Femtobasic for speccy heads. [noparse]:)[/noparse]
Yup, he did it! Asking for new features before the core project is done. <SMIRK>
OBC
"Unfortunately" the C64 is quite a lot more advanced and therefore harder to emulate. [noparse]:([/noparse]
But we have got some of the building blocks already implemented. (SIDcog and two different 6502 cores)
I will get myself a Dracblade and then we will see what will happen. [noparse]:)[/noparse]
The hardest part will be the VIC emulation.
