Boe-Bot Exercise question: Roaming with Whiskers and ramping up — Parallax Forums
VeganRobotVeganRobot Posts: 17
edited 2010-05-11 16:21 in Robotics
Hello,
First let me say what a blast electronics is, this coming from somebody who's really just getting into it. The Boe-Bot kit is amazing and I'm starting to get my head around programming but I have a question I was hoping somebody could shed some light on.
it's regarding the exercise Roaming With Whiskers and the BS2 code. I would like to add a servo-ramping up routine to the Forward, left, right, and back subroutines. After all Parallax recommends doing this to extend the life of the servos. I'm going to assume that you know which exercises I’m talking about as I haven't included any code in this post.
So i cut and paste the code from the ramping up BS2 exercise program and I put it into the forward_pulse subroutine. It works, but once it ramps up and the Pulse_Count variable hits 100, it starts all over again. so in other words it stops for about a half a second and ramps up again.
So i'm thinking what I need here is an IF...THEN statement that will determine that once the servos are at full speed forward (650,850) it keeps it at that speed until one of the whiskers is pressed and the respective subroutine is executed.
So I guess I'm asking: Is this the correct approach with a conditional IF...THEN, or am I over thinking it. I'd like to figure it out myself but if anyone has a few hints to move me a long that would be great.
Thanks.
  • Tony B.Tony B. Posts: 356
    edited 2010-05-10 02:14
    VeganRobot,
    It would be very helpful if you would post your code so we can see how you put it together. Without it is hard to help.
    Use the upload manager to upload your code file. You can do this by editing the above post by pressing on the little pencil icon in the upper right coner.
    I'm very glad you are discovering the joy of robotics and will do my best to help. The folks on the Parallax forum are a great group and more than willing to help.
    Tony
  • VeganRobotVeganRobot Posts: 17
    edited 2010-05-10 10:59
    Ok, had some time this morning. I've posted the code below. I've added the FOR...NEXT loop in the subroutine Forward, and I've annotated it as such.
    [noparse][[/noparse]code]' Robotics with the Boe-Bot - RoamingWithWhiskers.bs2
    ' Boe-Bot uses whiskers to detect objects, and navigate around them.
    ' Ramp up routines are addded to ease servo load.
    ' {$STAMP BS2} ' Stamp Directive
    ' {$PBASIC 2.5} ' PBASIC Directive
    DEBUG "Program Running"
    [noparse][[/noparse] Variables ]
    pulseCount VAR Byte ' FOR...NEXT loop counter.
    [noparse][[/noparse] Initialization ]
    FREQOUT 4, 2000, 3000
    [noparse][[/noparse] Main Routine ]
    DO
    IF (IN5 = 0) AND (IN7 = 0) THEN ' Both whiskers detect obstacle
    HIGH 10
    HIGH 1
    GOSUB Back_Up ' Back up & U-turn (left twice)
    GOSUB Turn_Left
    GOSUB Turn_Left
    ELSEIF (IN5 = 0) THEN ' Left whisker contacts
    HIGH 10
    LOW 1
    GOSUB Back_Up ' Back up & turn right
    GOSUB Turn_Right
    ELSEIF (IN7 = 0) THEN ' Right whisker contacts
    HIGH 1
    LOW 10
    GOSUB Back_Up
    GOSUB Turn_Left
    ELSE
    LOW 10
    LOW 1 ' Both whiskers 1, no contact
    GOSUB Forward_Pulse ' Apply a forward pulse
    ENDIF ' And check again
    LOOP
    [noparse][[/noparse] Subroutines ]
    Forward_Pulse: ' go forward and ramp up first
    FOR pulseCount = 1 TO 100
    PULSOUT 13, 752 + pulseCount
    PULSOUT 12, 748 - pulseCount ' here is where i added the FOR...NEXT
    PAUSE 20 ' command thinking it will check for the
    NEXT ' Pulsouts to reach max and then go back to
    IF pulseCount = 100 THEN ' the main program.
    DO
    PULSOUT 13, 850
    PULSOUT 12, 710
    PAUSE 20
    LOOP
    ELSE
    RETURN
    ENDIF
    Turn_Left: ' Left turn, about 90-degrees
    FOR pulseCount = 0 TO 20
    PULSOUT 13, 800
    PULSOUT 12, 650
    PAUSE 20
    NEXT
    PULSOUT 13, 650
    PULSOUT 12, 650
    PAUSE 20
    NEXT
    RETURN
    Turn_Right:
    FOR pulseCount = 0 TO 20 ' Right turn, about 90-degrees
    PULSOUT 13, 850
    PULSOUT 12, 850
    PAUSE 20
    NEXT
    RETURN
    Back_Up: ' Back up
    FOR pulseCount = 0 TO 40
    PULSOUT 13, 650
    PULSOUT 12, 850
    PAUSE 20
    NEXT
    RETURN
    Post Edited (VeganRobot) : 5/10/2010 11:52:02 AM GMT
    edited 2010-05-10 11:51
    hmmm, it doesn't format as well when i posted it, but you will notice my annotations are preceded by the ' key.
  • Jessica UelmenJessica Uelmen Posts: 490
    edited 2010-05-10 16:58
    Hi VeganRobot,
    I like your ingenuity, and am so glad to hear that you are enjoying the Boe-Bot kit! You're on the right track here, but let me see if I can help you get that extra step further.
    The original program, RoamingwithWiskers.bs2 executes subroutines based on the current states of the whiskers, as you already know. But if you take a look at the Forward_Pulse subroutine, you'll notice that only one pulse is sent to the servos. Now normally, sending one pulse to each servo will just make the Boe-Bot jerk a little bit, but in this instance, we're not sure how far the Boe-Bot will need to move forward until it hits something. And since the program executes so quickly, it looks like the Boe-Bot is steading moving forward when its really checking the whiskers, moving forward one pulse, checking the whiskers, moving forward one pulse, moving forward one pulse, checking the whiskers, and on and on until it detects that the whisker state has changed.
    So this is what is happening in your current program. It ramps each time because your main program is checking the state of the whiskers, seeing it needs to move forward, and then executes the ramping subroutine each time.
    But why then, isn't it catching on your IF...THEN statement? That's because after your FOR...NEXT loop finishes executing, counter is actually equal to 101. This is because the counter increments by one at the end of the loop each time even if it's reached it's limit, so your IF...THEN statement would need to check to see if counter is equal to 101. Try running this program to see for yourself:
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    counter VAR Byte
    FOR counter = 1 TO 100
      DEBUG HOME, ? counter
      PAUSE 20
    NEXT
    DEBUG ? counter
    END
    However, once the program "sees" that counter is equal to 101, you currently have it set to go into a DO...LOOP, where it will never break out and check the sensors again. So it might be a bit easier to put your IF...THEN statement before the ramping code, so that you can go back to only executing one forward pulse, checking the whiskers, moving forward one pulse, checking the whiskers, etc. It could look a little something like this:
    Forward_Pulse:
      IF pulseCount = 101 THEN
        PULSOUT 13, 852
        PULSOUT 12, 648
        PAUSE 20
      ELSE
          PAUSE 20
        NEXT
      ENDIF
    RETURN
    I hope this helps, and I apologize if the explanation is a little long winded. I just get excited when I see other people are excited! [noparse]:)[/noparse]
    Let us know how it goes!
    -- Jess
    Jessica Uelmen
    Education Department
    Parallax Inc.
    edited 2010-05-10 22:31
    Jess,
    Great information and help!! Thanks for helping.
    VeganRobot,
    As I was reviewing your code some other questions came up;
    1. In the Forward_Pulse: sub why do you start with 752 and 748 and the more traditional 750 for both?
    2. Do you intend to use ramping in all the movement subroutines?
    3. Not that what you have is wrong, I was wondering why you didn't ramp up by 250, thus your Pulsout commands would be at full speed of 1000 and 500?
    Like Jess, I would really like to know how the new code works out. Also, if you run into other problems don’t hesitate to post them here. As you can see both Parallax and forum members are more than willing to help solve problems you just can’t get past.
    Tony
    edited 2010-05-10 23:53
    Oh, I'm excited!!!!! I want to thank you for your responses. Yes, when you explain it like that it makes total sense. I know the book talks about why the program just uses a forward pulse instead of a loop (because of the checking every 40 times a second) but I just couldn't see why. My do...loop worried me as well. As you pointed out, the do...loop just locks the boe bot in a forward pulse train.
    Why did I use 752 and 748? Good question. I'm not sure why either but I think you're correct that it should start at the centering pulse of 750 apiece and then ramp up from there.
    I would like to use the ramping in all the movements as I can see how it will ease the wear and tear on the servos.
    I'm going to finish the code with ramping on all movements plus a few extras like more sounds when the whiskers hit something and more of a light show with the LEDs.
    I find these forums very useful, it can be somewhat intimidating getting into electronics for the first time but the help I get here coupled with the great products by Parallax makes it fun and encourages me to do more.
    Thanks to all, you'll probably see more posts as I move forward (pulse smile.gif
  • WhitWhit Posts: 4,194
    edited 2010-05-11 01:23
    VeganRobot,
    One more tip on posting code - other than the simple cut and paste that you did.·You can attach the code using the attach feature (bottom of post window - see below - people can just download the file) or cut and paste it in using the insert code feature (it is the "#" symbol on the post editor - stays in better shape - this is what Jessica did).
    Three examples are shown:
    1. Pasted in code (as you did)
    ' What's a· Microcontroller - FirstProgram.bs2
    ' BASIC Stamp sends a message to Debug Terminal.
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    DEBUG "Hello, it's me, your BASIC Stamp!"
    END
    2. Pasted in code (using the code paste feature - #)
    ' What's a  Microcontroller - FirstProgram.bs2
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    END
    3. Below is the attached file.
    Hope this helps! Great to have you on the forums.
    Whit+
    Post Edited (Whit) : 5/11/2010 1:35:40 AM GMT
    Thank you, that is much better!!!
