Surfact Mount Soldering Questions
On through the hole soldering, I'm told that a 30-40 watt soldering iron is good enough.
When I looked into surface mount soldering, I'm told to use a 50 watt temperature controlled iron.· What temperature should it be at and can you get away with using a 30 watt iron?· What are the pitfalls of not buying a good iron?
I do know there are chizel and 1/32inch tips for regular soldering irons but some are saying that it is only good for weekend hobbyists.
The cheapest SMS iron I've found is a Weller and I haven't done a lot of looking.· If anyone has any suggestions, I will take them.
The more I get into projects, the more reading I end up doing.
·http://www.radioshack.com/product/index.jsp?productId=3132686
You will have to check the store for availability though.
Extra tips can be bought here:
·http://www.madelltech.com/Soldertips.html
Jim
Temperature will depend on your solder type. 63/37 which is the best leaded solder to use but is not ROHS compliant melts at 183 °C so you want your temperature to be slightly above this(250 works really well)
For Lead Free solder you will have to turn the heat up a little to 250-300C
The most important thing with surface mount soldering is using the right tip. You want a tip that is small enough to apply the solder where you want it and no were else but big enough to transfer enough heat to the pin and attached traces. For this reason you will likely need a few different sizes of tips and will be constantly switching them out. Having a high wattage temperature controlled iron means that your tips after swapping will heat up to temp faster and even for very large traces will not cool down allowing good solder joints to be made.
Since you will likely have to swap out tips often it is good to look for an iron that makes this easy. To change the tip on a weller requires you to let the tip cool down first then unthread the end or to carefully unscrew it using a pear of pliers and do a fun dance to get the tip off without burning yourself. I use a JBC AD2700(now discontinued in favour of the AD2950) which has a special setup that allows for easy removal of tips and the tips heat up almost instantly. I beleive there are a few others that have similar quick change methods as JBC but I do not know which. An alternative that many people use is to buy a station that accepts 2 or 3 irons.
Once you get away from doing 1 offs or want to be able to solder BGA or QFN parts you will need to look into getting stencils made and using a reflow oven. This is the best approach as you can assemble several boards simultaneously(I do 12 propmod-us_ps_sd at a time) but does requiring you purchasing a stencil for every board design you make.
Lots of propeller based products in stock at affordable prices.
propmodule.com will be closed May 1-10th. Orders made in that time will be shipped on the 11th.
It has saved me SO much $$ its great .. It Will do Some SMT BUT no QFPs or small pitch stuff .
But SOIC stuff It does well WITH solder paste.
I did IPC SMT assembly certification in college with a PACE PRC2000 system .. it was a Joy to use . But those boxes of love are $900 Plus.
For any kinda SMT hot air works well IMHO .. But You have to use paste solder ..
Peter KG6LSE
"Carpe Ducktum" "seize the tape!!"
peterthethinker.com/tesla/Venom/Venom.html
Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
LOL
Leon Heller
Amateur radio callsign: G1HSM
Otherwise the Madell Tech AD201D is a lot cheaper.·
They have a temp controlled iron as well as the hot air system.
There are some pretty decent ones from China on ebay for just over $100
I had an old post somewhere here about ebay hot air stations...maybe search can find
it? I don't have much luck with the search here though.
Get a few extra tips for the iron, they are always cheaper when bought with the
hot air station. The stations usually come with 3 or 4 hot air nozzles...good enough
for starting out with.
There are some good video tutorials about hot air station work on youtube and
also some good ones at sparkfun.com.
Hot air is the only good way to de-solder a large sm chip.
You will praise the day you got a hot air station
Leon Heller
A vacuum pen is a great accessory.
I bought a 100 lot of un-named, unlabled, Smile ICs for $8.00 on Ebay to practice on initially. I wasted a few bucks on copper and etch but it didn't take long to get the confidence to do it "for real". ·Works for me : -)
73 de VA4MGW
Post Edited (Hobbyist) : 5/13/2010 12:18:57 AM GMT
suddenly just pops into alignment...like magic
seems to be OK.
They use something else at work, I'm not sure of the name.
But they have to keep it in a refrigerator.
I have had some similar problems with skittering 0805 parts.
The little devils try to escape when you are not looking
The lead free paste is even worse I think.
I looked up the paste you are using and it seems pretty much identical to
the syringes I use. The formulation is the same 63/37.
up way to fast..causing it to spit and boil.
I did a google on boiling solder paste and turned this up..so he may be right.
"If heated too rapidly the paste deposit can boil and spit. Gentle, indirect heating of solder paste is recommended throughout the soldering process. For this reason hot air heating is a very good method for use with solder pastes."
I think you're right about the fast heating. I forget that reflow is the opposite of conventional soldering where you heat, solder and get away quick.
