Was the gyro the wrong choice for this application?
I think I purchased the wrong thing for what I want to do.
I want to make a camera stabilizer that keeps the platform the camera is on horizontal reducing the effects of roll and pitch.
I thought each axis would be similar to a balancing bot so I got a LISY300 Gyroscope module thinking it gave tilt info only to find it gives rate of turn.
I am not understanding the values it is returning at all. Stationary it gives 505, the number then goes up/down randomly seemingly no matter
which way I turn it. I would think it would go down one direction, up the other?
I am totally confused on what information it is giving me.
the LISY300 Gyroscope Module can detect how many degrees it has turned on its planar axis
How do I get that value?!?!?!?
This is the code I am using that was on the product page, I modified it to print the measurement value to the serial terminal.
CON ' Propeller Setup _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 CON ' Gyro I/O Pins DOUT = 0 SCLK = 1 nCS = 2 VAR ' Gyro long Center long Deg OBJ DEBUG : "Parallax Serial Terminal" PUB MAIN dira[noparse][[/noparse]2..1]~~ Measure Calibrate DEBUG.start(250000) DEBUG.clear repeat DEBUG.Position(20,20) DEBUG.str(string("Gyro angle: ")) DEBUG.clearend DEBUG.dec(measure) Measure Calibrate PUB Calibrate | Value, Sigma, Minimum, Maximum, Average result~ Sigma~ Minimum := Maximum := Measure repeat 50 Sigma += Value := Measure ' Sum Voltage Readings Minimum <#= Value ' Find Minimum Voltage Maximum #>= Value ' Find Maximum Voltage Average := Sigma / 50 ' Find Average of Samples Center := Average PUB Measure ' Clock data in for 13 bits. (First three are zero, next ten are data.) result~ outa[noparse][[/noparse]nCS]~ repeat 13 outa[noparse][[/noparse]SCLK]~ outa[noparse][[/noparse]SCLK]~~ result := result << 1 | ina[noparse][[/noparse]DOUT] outa[noparse][[/noparse]nCS]~~Deg := Deg + (Center - Measure) / 2
of roll using a servo to control the platform. This is what I got so far.
'servo.init dira[noparse][[/noparse]2..1]~~ Measure Calibrate DEBUG.start(250000) DEBUG.clear repeat DEBUG.Position(20,18) DEBUG.str(string("Gyro Center: ")) DEBUG.clearend DEBUG.dec(center) DEBUG.Position(20,19) DEBUG.str(string("Gyro measure: ")) DEBUG.clearend av := avermeasure if av > 508 or av < 504 Deg := Deg + (Center - Measure) / 2 DEBUG.dec(deg) DEBUG.Position(20,20) DEBUG.str(string("Gyro angle: ")) DEBUG.clearend degree := deg / 39 if degree > 30 degree := 30 if degree < -30 degree := -30 DEBUG.dec(degree) DEBUG.Position(20,21) DEBUG.str(string("Servo angle: ")) DEBUG.clearend if degree > 0 servopos := 110 + (degree * 4) else servopos := 110 - (||degree * 4) DEBUG.dec(servopos)Bill
