Ford Starter Switch
I would like to use a Ford style starter switch to send power to my large bot motors.· I tried putting 12V @3A·across the two small terminals on the front but the relay switch didn't close.
Can anybody tell me how to trigger the relay ?·· Thanks, Newbe
- Stephen
My 94 aerostar does this.... 3 terminals...
2 big terminals that are closed by the relay.
One small one that·I send 12vdc into to·close the relay.
And ground passes thru the body of relay·into the screw·& tehn into the body of the car wich is tied to the ground of the battery!!!
Hope this helps!· But if not, what car did the relay come from?????
Before you criticize someone, walk a mile in his shoes. That way if he gets angry, he'll be a mile away and barefoot. - unknown
You'll notice that the pictured relay one has 2 small terminals....... the bottom of the BODY is still the ground tho.
Sometimes those 2 little terminals are connected & sometimes one does nothing.· You should use a meter to check for resistance to determine the coil connections... As I recall..some Fords sent a signal to the ignition coil thru that extra pin, to have it adjust the timing while starting the car.
Anyway...the person here was using it to control an electric fan in a car.....same theory as yours.
Post Edited (sumdawgy) : 5/6/2010 4:36:13 AM GMT
Fun fact: the standard value of the condenser (AKA capacitor for those born after the first gas crisis, when electronic ignitions replaced points) is ~0.22 uF.
also my 68 mustang has the exact same looking one I hope hope this helps I actually went outside I and tried what I am telling you and it worked .. If this is not clear feel free to call me
860 349 9789 Mike I can talk you through it I am home most days
The smarter I get, the more I understand I don't know!
