Hacking a PowerWheels Car as a light Robotics platform — Parallax Forums
Peter KG6LSEPeter KG6LSE Posts: 1,383
edited 2010-08-06 12:54 in General Discussion
Hacking a PowerWheels Car as a light Robotics platform .
I plan on using a VEX V.5 brain as the main brain mostly cause VEXNET is so awsome and its IMHO easer to use for me .I have used it a lot for FIRST robotics so I know how to use it
And a BS2 as a Sub brain chip to integrate sensors in to the VEX like GPS PING))) Acelll and also the housekeeping funtions
I may bump it to a Prop later on .
I have had this idea for many months But did not have the $$ .. but I got some cash to tinker with this week so I went shopping today
I first looked at a larger Quad bike at wally world but it was a tad to large and was $180
But target had one in the back this slightly smaller one for $99
So I got it ..
BTW my floor tiles are 1x1 foot for scale ..
The Only small issue is its 1 wheel drive . the right rear is not powered, just the left .
I noticed it after I assembled it but its not a huge issue ..
I am going to tye them together as one . NO differential but at this size device I dont rely care .
The Only part that I need to be careful on is the steering servo . I will have to make it strong !!I guess a $250 one will be big enough I hope ..
but so far it looks like a good base to hack .
I figure its 6V drive system can handle 7.2V RC pack voltage with out to much harm .
Now to build it ! by fall term Whoot!
Peter KG6LSE
"Carpe Ducktum" "seize the tape!!"
peterthethinker.com/tesla/Venom/Venom.html
Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
LOL
Post Edited (Peter KG6LSE) : 5/2/2010 10:17:49 PM GMT
  • P!-RoP!-Ro Posts: 1,189
    edited 2010-05-02 22:32
    I'm running a powerwheels motor for the steering on my 150lb bot at 12v no problem. It even works well off of my 10A control system. For the steering it shouldn't be too bad if you get something like a window motor, free if you go to a repair shop.
    Got 150 pounds of bot and growing.
    edited 2010-05-03 15:10
    Today I am working on the 1 wheel Drive issue .
    And doing a current test to see how many amps the system draws to decide on the kind and type of batt pak needs to be made .
    Cause a 7AH 6V batt is not big enough IMHO ..
    I am hoping its not too high as I want to use NiMh and not SLA batts..
    Li-xxx is not a option ...
    then I need to to a torque mesurement to get the right size servo .
    PI'd thanks for the idea . I have heard of that trick many times but At this time a window motor would be too much hassle ..
    I have no machine capabilities so I need to think COTS for the device for now ..
    Peter KG6LSE
    LOL
  • zappmanzappman Posts: 418
    edited 2010-05-03 15:55
    I saw a R/C truck on sale (on 5/1/2010)
    Silverado Truck 6V Remote Control & Ride On
    $99.99 each
    Compare at $219.99
    Drive the fun home with the Silverado 6V Remote-Controlled Ride-On by National Products Ltd. This ride-on has two modes: In normal battery-operated position, the vehicle can be controlled by a child with simple throttle and forward and reverse gears. In remote-control mode, the vehicle becomes a giant radio-controlled vehicle that can be controlled by parents. The remote-controlled mode is ideal for small children who are too young to operate the ride-on by themselves. Battery-operated ride-on can be switched to become a remote-controlled vehicle 3:1 scale vehicle. Features forward and reverse gears, working horn and cool engine sounds. Max speed as ride-on: 2 mph
    at http://shop.tuesdaymorning.com/dsp_productDetail.asp?ssid=1&pid=7595
    You can find more details on it at www.npl2.com including a video.
    It is already set up to be driven by a child while sitting on it or driven by the parent via r/c, there is a change over switch under the seat.
    I was thinking about getting one of these, and hooking it up, to the BOE Stamp board from my BOEBOT, via the 2 HB-25s I have.
    How do you think this combo would work?
    I figure later I could up grade it to a propeler board.
    (Maybe this thread should be moved to robots forum?)
    zappman
    Post Edited (zappman) : 5/3/2010 4:17:05 PM GMT
    920 x 920 - 108K
  • ScopeScope Posts: 417
    edited 2010-05-03 16:40
    This should be enough servo power:
    www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.2546/.f
    or, this one (check out the torque on the chart)
    www.hobbypartz.com/12exiseb1.html
  • W9GFOW9GFO Posts: 4,010
    edited 2010-05-03 17:51
    Peter KG6LSE said...
    Today I am working on the 1 wheel Drive issue...
    Back in the early 80's there was this really cool RC car called "Fat Wheels". It was called that because the tires were inflatable via a tiny tube that was tucked into the rim. The first thing I noticed when I finally got one was that it would turn much faster in one direction than the other. This really bothered me so I had to investigate. As you can probably guess, it was a one wheel drive. Symmetry is important to me so I modified it into a live axle - just like the old three wheeler ATV's.
    The result was that it now turned equally poorly in both directions - but it tracked really straight!
    You shouldn't have as much trouble with the plastic wheels. If you do make it a live axle I would suggest that you do it in such a way that you can easily undo the modification.
    Rich H
    I tried to find a picture of the Fat Wheels toy but I had no luck. [noparse]:([/noparse]
    Success!
    Fat Wheels commercial
    The Simple Servo Tester, a kit from Gadget Gangster.
    Post Edited (W9GFO) : 5/3/2010 6:09:35 PM GMT
    edited 2010-05-03 23:15
    the Mod Went VERY well
    I also Found some Servos with 34Kg Cm to use
    But I do have one issue .
    Speed Cons have changed in the years since I did RC back as a kid ( 04) ..
    I am having a hard time finding a 40A Reversible non brush less Speed con new that can handle up to 12 V .
    I may just buy the one from VEX..
    the Stall current is 13Amps or so on the motor ..
    EDIT I am am after all going to use the VEX Speed Con ..
    Peter KG6LSE
    LOL
    Post Edited (Peter KG6LSE) : 5/4/2010 10:48:01 PM GMT
    edited 2010-05-05 23:54
    I have decided on a VEX VICTOR Speed Con there a tad pricy but I know that they Will work ..
    "first Light" is very critical to me .. I want it to at least be a RC in the next 3 Weeks .
    For the servo I have 3 ideas .
    Eather
    As mentioned above .. its cheap so I will try it first ..
    Or I did find a HUGE one
    0J1905.600.jpg?1256955890
    www.pololu.com/catalog/product/1390
    its more then a new VEX Brain but its Ideal .
    www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.6595/.f
    Peter KG6LSE
    LOL
    Post Edited (Peter KG6LSE) : 5/8/2010 4:06:12 PM GMT
  • logan996logan996 Posts: 281
    edited 2010-05-07 01:17
    sooooo off topic but what team are you in the FIRST FRC leauge? did you go to the BMR Regional? (boilermaker) My team is 1501! so you have a homepage i could maybe see? sorry again for how off topic this is
    edited 2010-05-07 02:43
    I was part team MSAC for VEX my college (Old,,, Mt SAC) nor my current IHCC one does Full FRC )
    we won the College excellence!! award at the world comp in TX last year ..
    we were also known as SPS 1501 LOLs . Society of physics students 1501 But college uses letters ..
    Here is a video of my team at the world champs ..
    www.youtube.com/watch?v=62MrS-SVyoo
    I built BETA and did all the batt maintenance and was a team leader .
    I was going to be a driver for BETA but I am not good at driving so I handed that off to a anther student .
    Nom I did act as a mentor for FRC team 294 Beach citys Robotics BCR for many years ..
    Peter KG6LSE
    LOL
  • edited 2010-05-07 14:38
    Peter,
    Cool video.· I watched some of your other videos and found them interesting.
    Chuck
    edited 2010-05-07 17:02
    Apeture Science......we do what we must because we can... [noparse]:)[/noparse]
    Shawn Lowe
    When all else fails.....procrastinate!
    edited 2010-05-07 21:10
    nice, you shoiuld see ours, look up first 1501 on youtube we have a 3 wheeled robot and should be on youtube, i think there is an account called huntingtonrobotics that might be us if there is one
    "When the government is afraid of the people there is liberty, when the people are afraid of the government, there is tryanny"
    · Thomas Jefferson
    edited 2010-05-11 23:54
    Ok First Light for the speed con Went Very Well !!
    Too Well if there is such a thing .
    www.flickr.com/photos/peterthethinker/4599477849/ Video
    Now Off to Servo Land .
    Peter KG6LSE.
    LOL
    edited 2010-05-12 21:12
    Ground Test for speed
    I did some SW hacks to tweak the dead-band and also adjust the Plug Breaking
    www.flickr.com/photos/peterthethinker/4602432914/ Video
    Peter KG6LSE
    LOL
    edited 2010-05-12 21:40
    Hmm, nice and slow robot. Wish I knew how to make those [noparse]:)[/noparse]
    What do you plan to make it do?
    edited 2010-05-12 22:46
    its replaceing a RC Hummer that had Bi audio and video on it .. In the case of DORTHY its also going to get some smarts .... think of the DARPA grand project a few years ago ..... just on a mutch smalller scale...
    peter KG6LSE ... on cell phone
    LOL
    edited 2010-05-15 18:53
    BUmp for new News .
    Iam heading to cali in a few days for summer break ,,
    I know of some massive Hobby stores there so I am going to try to get the servo there first .
    Peter KG6LSE
    LOL
    edited 2010-05-21 00:58
    Update..
    I got a JR 8911HV servo today..
    Its 470 Oz Inches so I hope it will be enough to drive this thing ..
    My Gut says Its plenty of power ..
    Iam back In LA so I won't be able to test said servo on Dorthy but I will be back to Iowa in the lab in a few weeks .
    KG6LSE
    LOL
    edited 2010-05-21 16:07
    Peter: Welcome back to LA.
    Didn't know you were schooling in Iowa. Maybe you can move on this item that John R. PM'ed me about, because of my signature line!
    http://www.huffingtonpost.com/2010/05/14/field-of-dreams-for-sale_n_576064.html
    Looking forward to meeting you next Saturday at the TRW Swap meet. Any other Forum members near LA headed that way?
    http://www.w6trw.com/swapmeet/swapmeet.htm
    edited 2010-06-02 18:45
    OK· I· lust· mounted· the·· Servo·· to the stearing system ..
    I· will have photos··· tonoght··· and maby·· just··· maby··· a··· full tether· drive·· test··· !!!
    Peter· KG6LSE
    LOL
    edited 2010-06-04 00:00
    After a few minits in Lab I got Full Drive working !! so I guess I am one step closer to My dream .
    www.youtube.com/watch?v=Pn99qOn9-5k First Light of the Servo added ..
    peter KG6LSE
    LOL
    edited 2010-06-15 22:00
    I got the servo Mounted better and I mounted the AGM Batts and made a servo cable .
    Servo Mount ..
    Batt R
    Batt L
    I am pleased How exact the Bottom Rails hold the Batts ! I swear I did not plan that measurement !
    It fits Just right ..Its Very stable ! with the Batts so close to the center .
    This Confirms my Original thoughts .
    I Hate to say this but it is seeming Too Easy at this point ...
    Peter KG6LSE
    LOL
    Post Edited (Peter KG6LSE) : 7/3/2010 7:02:09 PM GMT
    384 x 307 - 22K
    384 x 307 - 28K
    384 x 307 - 28K
    edited 2010-06-30 00:33
    I got some SW I am working on for the BS2 Sub Brain .. sadly the only role the BS2 is serving is as a Batt Gauge .
    BUT soon it will be I hope sending Video over lay on the TX Video stream . Via a Prop Back backpack . My teletrmitry Like Batt , Temp speed Compass ECT ..
    The SW is still on paper and in my head ......
    Peter KG6LSE
    LOL
    edited 2010-08-05 03:34
    I will try to get the extra TV TX and the Prop back pack and the BS2 by the fall term .
    So I hope to have that part of it done then ..
    I do how ever have a cool clip from me in lab with it tonight .. I wanted to see how strong it is .
    www.flickr.com/photos/peterthethinker/4862221548/
    Lets just say its no speed demon but it can shure haul a good load ..
    Peter KG6LSE
    LOL
    edited 2010-08-05 15:16
    Sweet ride, but you're still 400 LEDs short. [noparse]:)[/noparse]
    edited 2010-08-05 17:54
    Perhaps you should try a prop proto board first. It's cheaper and can have parts soldered on to do much more than the backpack.
    edited 2010-08-06 09:43
    pi'd I would but here is the catch .]
    DORTHY is ment to be COTS as much as possable .
    So if there is anyway to simplify her will .
    and I the backpack Just works . its exactly what I need as of now .
    It has Sync Overlay..
    Erco ..We have HS students come here often so I rigged a 100W speeker system to it last week . it played "still alive" from portal and some bach too.
    I have thought on installing some lights too..
    from what can gather about pulling power its a traction issue more then a power issue.
    I have class from 10 AM to 10PM so I have no time to work on her .
    so she is not progressing as fast as I want .
    fall term ( with all the new students ) is next month so she needs
    to be at least doing raw Video/Audio TX and RX in 2 weeks and
    the RC TX needs fixing . there is no RF output so she is on teather for now . this is not ok .
    a new TX is 150 or so but the data on the teather is only just slow-er serial so If I can I may use some COTS trancevers to get around the teather isue
    Peter KG6LSE
    edited 2010-08-06 11:47
    I understand how the traction issues go, I modified my robot yesturday to have a split axle so now that one tire can make a pretty good fountain of dirt (not ok if I want the bot to be moving). You ever think of adding rubber tires?
    edited 2010-08-06 11:56
    actuly it has rubber strips in its wheels . It was one of the bonusis on the one I chose .
    I think its a weight issue . there is no 40Lb kid on it to shove the wheels on to the floor .hehe.
    as of now its like less then 20Lbs .
    and because I have no Diff on the drive train anymore grip would make steering worse . . Mind its not bad at all! but because she will never drag anythng big (like me ) In normal operation there shuld be no need for more grip ..
    Well, can you at least take it out to the parking lot and make it do donuts?
