Vishay display APD-128G032
I would like to attach a Vishay APD-128G032 Display to my Stamp processor to send it serial data.
I wanted to create this to help everybody else who might be wanting to do something simular to this.
Here is the specs on that display:
www.vishay.com/docs/37006/apd128g.pdf
What I understand so far is that i will need power which i think i have done. then i need to send it a few signals to turn the display on and off as i send it data at a set hertz.
I'm not 100% sure the order in which i have to enable and disable things and when i should be sending data , and how to send that kind of data with a stamp. Also does the Basic Stamp 2 learning project kit come with some kind of a crystal clocking source?
Any help or snippets that people submit are greatly appreciated. Thanks!
- Stephen
- Stephen
pin 2 4 6 8 10 12 14 are all grounds so i put them on two rows on the bread board and then but them to the ground bar.
1 is the display enable
3 is row data
5 is row clock
7 column latch
9 dot clock
11 serial data
13 is not connected.
i attached it to the basic stamp 2 as follows
Pin 1 - 1
pin 3 - 2
pin 5 - 3
pin 7 - 4
pin 9 - 5
pin 11 - 6
the power i'm using is from a machine that the display came from so i'm fairly confident i've done the power correctly...
- Stephen
' {$STAMP BS2} ' {$PBASIC 2.5} rowcounter VAR Byte ' -----[noparse][[/noparse] EEPROM Data ]----------------------------------------------------- 'setup a line that repeats vertial posts | put this in every line solidBar DATA %10101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010 PAUSE 1000 'must set clock on in/out 5 ?? DO rowcounter = 0 'blank counter LOW 1 ' turn off "display enable" during inputs LOW 4 ' turn off "latch" during inputs must be done after display enable goes low HIGH 2 ' turn on to signal first row comming HIGH 3 ' rise before sending data OUT6 = solidBar LOW 3 'fall after sending data HIGH 4 'kick on latch to send data to output HIGH 1 'enable display to show our image 'do this only once because the first is different from the rest DO LOW 1 ' turn off "display enable" during inputs LOW 4 ' turn off "latch" during inputs must be done after display enable goes low HIGH 3 ' rise before sending data OUT6 = solidBar LOW 3 'fall after sending data HIGH 4 'kick on latch to send data to output HIGH 1 'enable display to show our image rowcounter = rowcounter + 1 LOOP UNTIL rowcounter = 31 LOOPPost Edited (edge87) : 5/5/2010 10:01:34 PM GMT
- Stephen
' {$STAMP BS2} ' {$PBASIC 2.5} rowcounter VAR Byte sendthis VAR byte 'the data for the row loop line0 VAR word line1 VAR word line2 VAR word line3 VAR word line4 VAR word line5 VAR word line6 VAR word line7 VAR word line8 VAR word line9 VAR word line10 VAR word line11 VAR word line12 VAR word line13 VAR word line14 VAR word line15 VAR word line16 VAR word line17 VAR word line18 VAR word line19 VAR word line20 VAR word line21 VAR word line22 VAR word line23 VAR word line24 VAR word line25 VAR word line26 VAR word line27 VAR word line28 VAR word line29 VAR word line30 VAR word line31 VAR Word 'really this is line 32 the final line on the display. We started at 0 for the loop init. ' -----[noparse][[/noparse] EEPROM Data ]----------------------------------------------------- 'setup variables to hold our display message (gota find a better way to do this, seems like a major waste of memory (could use a blank line and reuse it) line0 = "00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000" line1 = "00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000" line2 = "00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000" line3 = "00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000" line4 = "00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000" line5 = "00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000" line6 = "00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000" line7 = "00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000" line8 = "00000000000000000000000000000000000000001100000000000000000000000000000000000000000000000000000000000000000000000000000000000000" line9 = "00000000000011000001100000110000000000001100000000000000000000000000000000000000000000000000000000000011000000000001100000000000" line10 = "00000000000011000001100000110000000000001100000000000000000000000000000000000000000000000000000000000011000000000001100000000000" line11 = "00000000000001100001110001100000000000001100000000000000000000000000000000000000000000000000000000000011000000000001100000000000" line12 = "00000000000001100011110001100001111100001100000111100000111100000011011110011110000001111100000000000011000000000001100000000000" line13 = "00000000000001100010010001100111111110001100011111110011111111000011111111111111000111111110000000000011000000000001100000000000" line14 = "00000000000001100010010001100110000111001100011000010011000011000011100011100011000110000111000000000011000000000001100000000000" line15 = "00000000000000110010011001001100000011001100110000000110000001100011000011000011001100000011000000000011000000000001100000000000" line16 = "00000000000000110110011011001111111111001100110000000110000001100011000011000011001111111111000000000011000000000001100000000000" line17 = "00000000000000110100001011001111111111001100110000000110000001100011000011000011001111111111000000000011000000000001100000000000" line18 = "00000000000000110100001011001100000000001100110000000110000001100011000011000011001100000000000000000000000000000000000000000000" line19 = "00000000000000011100001110000110000001001100111000010011000011000011000011000011000110000001000000000000000000000000000000000000" line20 = "00000000000000011100001110000111111111001100011111110011111111000011000011000011000111111111000000000011000000000001100000000000" line21 = "00000000000000011000000110000001111110001100001111100000111100000011000011000011000001111110000000000011000000000001100000000000" line22 = "00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000" line23 = "00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000" line24 = "00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000" line25 = "00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000" line26 = "00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000" line27 = "00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000" line28 = "00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000" line29 = "00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000" line30 = "00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000" line31 = "00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000" PAUSE 1000 'must set clock on in/out 5 ?? DO rowcounter = 0 'blank counter LOW 1 ' turn off "display enable" during inputs LOW 4 ' turn off "latch" during inputs must be done after display enable goes low HIGH 2 ' turn on to signal first row comming HIGH 3 ' rise before sending data SERout 6, 9600, [noparse][[/noparse]line0] LOW 3 'fall after sending data HIGH 4 'kick on latch to send data to output HIGH 1 'enable display to show our image 'do this only once because the first is different from the rest DO sendthis = "line" + rowcounter LOW 1 ' turn off "display enable" during inputs LOW 4 ' turn off "latch" during inputs must be done after display enable goes low HIGH 3 ' rise before sending data SEROUT 6, 9600, [noparse][[/noparse]sendthis] LOW 3 'fall after sending data HIGH 4 'kick on latch to send data to output HIGH 1 'enable display to show our image rowcounter = rowcounter + 1 LOOP UNTIL rowcounter = 31 LOOP▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
- Stephen
I have also purchased a propeller learning kit, and a propeller chip for building this project. Will i have much better luck with a propeller? being that it is 32 bit?
- Stephen
