Bar Graph (Advanced) What need to be change to have an output from the MAX186 s
This from my from my meter code
The scale for this one is· 0 to 50 C and a scale 0 to 125 F
I want to display it as a Bar Graph this code·using this what need to be changed
I also want to use this as well and I want to display it as a Bar Graph this code·using this what need to be changed
I aslo have where I to do the same thing with voltage 0 to 4 volts·
Thank to any one that can help
·Now wanting to learn Spin· Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 5/4/2010 2:38:32 PM GMT
SEROUT TX, T2400, [noparse][[/noparse]LcdCls] DO PAUSE 5 LOW CS ' Enable ADC SHIFTOUT DataIn, Clock, MSBFIRST, [noparse][[/noparse]%10111101] ' Select CH0, Single-Ended [noparse][[/noparse]%1XXX1101] SHIFTIN DataOut, Clock, MSBPOST, [noparse][[/noparse]KLN\12] ' Read ADC HIGH CS ' Disable ADC tC = KLN - 275 ' convert to tenths C SEROUT TX, T2400, [noparse][[/noparse]LcdLine1, "TC ", DEC TC] ' Displays voltages & digital value LOW CS ' Enable ADC SHIFTOUT DataIn, Clock, MSBFIRST, [noparse][[/noparse]%11111101] ' Select CH7, Single-Ended SHIFTIN DataOut, Clock, MSBPOST, [noparse][[/noparse]KLN1\12] ' Read ADC HIGH CS ' Disable ADC tC1 = KLN1 - 275 ' convert to tenths C SEROUT TX, T2400, [noparse][[/noparse]LcdBLon, LcdLine1_1, "TC1 ", DEC TC1] ' Displays voltages & digital value LOW CS ' Enable ADC SHIFTOUT DataIn, Clock, MSBFIRST, [noparse][[/noparse]%11001101] ' Select CH1, Single-Ended [noparse][[/noparse]%1XXX1101] SHIFTIN DataOut, Clock, MSBPOST, [noparse][[/noparse]results0\12] ' Read ADC HIGH CS Volts0 = results0 */ Cnts2Mv IF volts0 > 1 THEN SEROUT TX, T2400, [noparse][[/noparse]LcdLine1_2, "VT ",DEC Volts0 ] ELSE SEROUT TX, T2400, [noparse][[/noparse]LcdLine1_2, "V ____" ] SEROUT TX, T2400, [noparse][[/noparse]LcdLine2, " " ] PAUSE 100 ENDIF LOOP
' -----[noparse][[/noparse] Initialization ]-------------------------------------------------- HIGH LCD ' Setup Serial Output Pin PAUSE 100 ' Give LCD Time To Settle Download_Chars: FOR index = 0 TO 45 ' Download Custom Characters READ CC0 + index, work ' Read EEPROM Data SEROUT LCD, Baud, [noparse][[/noparse]work] ' Send To LCD CGRAM NEXT SEROUT LCD, Baud, [noparse][[/noparse]LcdOn1, LcdBLon] ' Turn LCD Display & Backlight On ' Backlight Only On Backlit Models PAUSE 10 ' Allow LCD Time To Settle highVal = 255 ' You can change this value to any ' Non-Zero value ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Main: DO SEROUT LCD, Baud, [noparse][[/noparse]LcdCls] ' Clear LCD Screen PAUSE 10 ' Must Follow CLS FOR index = 0 TO highVal ' Count To highVal can add (Step 100} GOSUB Disp_Graph ' Update Display NEXT PAUSE 5000 ' Wait 5 Seconds Then Repeat LOOP ' Forever STOP ' -----[noparse][[/noparse] Subroutines ]----------------------------------------------------- Disp_Graph: perCent = ((index * 100) / highVal) ' Draw index, highVal and perCent Values. This line can be removed. SEROUT LCD, Baud, [noparse][[/noparse]LcdLine1, DEC5 index, "/", DEC5 highVal, "=", DEC perCent, "%"] ' Draw Header And Left-Most, Solid Blocks SEROUT LCD, Baud, [noparse][[/noparse]LcdLine2, "0%", REP 4\(perCent MIN 1 - 1 / 10)] ' Draw Partial Block IF perCent > 0 THEN SEROUT LCD, Baud, [noparse][[/noparse](perCent - 1 / 2) // 5] ' Draw Right-Most, Blank Blocks And Footer SEROUT LCD, Baud, [noparse][[/noparse]REP 32\10 - ((perCent + 9) / 10), "100%"] RETURN
' -----[noparse][[/noparse] Initialization ]-------------------------------------------------- HIGH LCD ' Setup Serial Output Pin PAUSE 100 ' Give LCD Time To Settle Download_Chars: FOR index = 0 TO 72 ' Download Custom Characters READ CC0 + index, work ' Read EEPROM Data SEROUT LCD, Baud, [noparse][[/noparse]work] ' Send To LCD CGRAM NEXT SEROUT LCD, Baud, [noparse][[/noparse]LcdOn1, LcdBLon] ' Turn LCD Display & Backlight On ' Backlight Only On Backlit Models PAUSE 10 ' Allow LCD Time To Settle highVal = 5000 ' You can change this value to any ' Non-Zero value ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Main: DO SEROUT LCD, Baud, [noparse][[/noparse]LcdCls] ' Clear LCD Screen PAUSE 10 ' Must Follow CLS FOR index = 0 TO highVal ' Count To highVal can add (Step 100} GOSUB Disp_Graph ' Update Display NEXT PAUSE 5000 ' Wait 5 Seconds Then Repeat LOOP ' Forever STOP ' -----[noparse][[/noparse] Subroutines ]----------------------------------------------------- Disp_Graph: perCent = (index / (highVal / 100)) ' Calculate Percent Value ' Draw index, highVal and perCent Values. This line can be removed. SEROUT LCD, Baud, [noparse][[/noparse]LcdLine3, DEC5 index, " / ", DEC5 highVal] ' Draw Header And Left-Most, Solid Blocks SEROUT LCD, Baud, [noparse][[/noparse]LcdLine1, "0% ", REP 4\(perCent MIN 1 - 1 / 10)] ' Draw Partial Block IF perCent > 0 THEN SEROUT LCD, Baud, [noparse][[/noparse](perCent - 1 / 2) // 5] ' Draw Right-Most, Blank Blocks And Footer SEROUT LCD, Baud, [noparse][[/noparse]REP 32\10 - ((perCent + 9) / 10), DEC perCent, " %"] SEROUT LCD, Baud, [noparse][[/noparse]LcdBLon ,LcdLine2,5,7,7,7,7,7, 6," KW"] RETURN
Sam
Sam
Post Edited (sam_sam_sam) : 5/4/2010 2:35:01 PM GMT
Sam
Chris Savage
Parallax Engineering
also how do you scale the bar graph as well
Sam
Chris Savage
How do you take the data that you have from the ADC part of the code and Put in·to the Bar Graph part of the code
There is where I am··I am ·REAL·Lost or just have REAL big brain f
Sam
Post Edited (sam_sam_sam) : 5/5/2010 8:33:49 PM GMT
Chris Savage
Chris Savage
Chris Savage
Could you also post the code that you used
Thanks for your help
Sam
Yep, got the programs and code done last night here at work, however I had forgotten when I got home that my main PC is down and the HD had just arrived. I didn't have time to install it last night. I will get it back up tonight though. If you're not sure what I am talking about, see this post.
Or this one.
Chris Savage
I do understand and I did read·that post on your web site
Please take a much as you need I am in no big hurry· I just want to know how you do this
Thanks for you time and help in this project
Sam
Chris Savage
Episode 5: Merging Programs Part 1 of 2
Episode 6: Merging Programs Part 2 of 2
Chris Savage
That was a GREAT how to do video
·············································· That help alot
········································································ ·Thanks
····························································································· I got it to work
Sam
Chris Savage
The second part video (Episode 6) has been fully updated and posted at the link above. It gives more details than I thought I had time for originally.
Chris Savage
Thanks for taking the time to make this video. You explain alot in a clear manner that helps people like me really understand the thinking process in merging programs together. Well done!
Shawn Lowe
When all else fails.....procrastinate!
Chris Savage
The info that you add at the end ·WAS GREAT··that helps alot Thank for all of your help
Sam
Sam
