Bar Graph (Advanced) What need to be change to have an output from the MAX186 s
This from my from my meter code
The scale for this one is· 0 to 50 C and a scale 0 to 125 F
I want to display it as a Bar Graph this code·using this what need to be changed
I also want to use this as well and I want to display it as a Bar Graph this code·using this what need to be changed
I aslo have where I to do the same thing with voltage 0 to 4 volts·
Thank to any one that can help
·Now wanting to learn Spin· Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 5/4/2010 2:38:32 PM GMT
SEROUT TX, T2400, [noparse][[/noparse]LcdCls]
DO
PAUSE 5
LOW CS ' Enable ADC
SHIFTOUT DataIn, Clock, MSBFIRST, [noparse][[/noparse]%10111101] ' Select CH0, Single-Ended [noparse][[/noparse]%1XXX1101]
SHIFTIN DataOut, Clock, MSBPOST, [noparse][[/noparse]KLN\12] ' Read ADC
HIGH CS ' Disable ADC
tC = KLN - 275
' convert to tenths C
SEROUT TX, T2400, [noparse][[/noparse]LcdLine1, "TC ", DEC TC] ' Displays voltages & digital value
LOW CS ' Enable ADC
SHIFTOUT DataIn, Clock, MSBFIRST, [noparse][[/noparse]%11111101] ' Select CH7, Single-Ended
SHIFTIN DataOut, Clock, MSBPOST, [noparse][[/noparse]KLN1\12] ' Read ADC
tC1 = KLN1 - 275 ' convert to tenths C
SEROUT TX, T2400, [noparse][[/noparse]LcdBLon, LcdLine1_1, "TC1 ", DEC TC1] ' Displays voltages & digital value
LOW CS ' Enable ADC
SHIFTOUT DataIn, Clock, MSBFIRST, [noparse][[/noparse]%11001101] ' Select CH1, Single-Ended [noparse][[/noparse]%1XXX1101]
SHIFTIN DataOut, Clock, MSBPOST, [noparse][[/noparse]results0\12] ' Read ADC
HIGH CS
Volts0 = results0 */ Cnts2Mv
IF volts0 > 1 THEN
SEROUT TX, T2400, [noparse][[/noparse]LcdLine1_2, "VT ",DEC Volts0 ]
ELSE
SEROUT TX, T2400, [noparse][[/noparse]LcdLine1_2, "V ____" ]
SEROUT TX, T2400, [noparse][[/noparse]LcdLine2, " " ]
PAUSE 100
ENDIF
LOOP
' -----[noparse][[/noparse] Initialization ]--------------------------------------------------
HIGH LCD ' Setup Serial Output Pin
PAUSE 100 ' Give LCD Time To Settle
Download_Chars:
FOR index = 0 TO 45 ' Download Custom Characters
READ CC0 + index, work ' Read EEPROM Data
SEROUT LCD, Baud, [noparse][[/noparse]work] ' Send To LCD CGRAM
NEXT
SEROUT LCD, Baud, [noparse][[/noparse]LcdOn1, LcdBLon] ' Turn LCD Display & Backlight On
' Backlight Only On Backlit Models
PAUSE 10 ' Allow LCD Time To Settle
highVal = 255 ' You can change this value to any
' Non-Zero value
' -----[noparse][[/noparse] Program Code ]----------------------------------------------------
Main:
DO
SEROUT LCD, Baud, [noparse][[/noparse]LcdCls] ' Clear LCD Screen
PAUSE 10 ' Must Follow CLS
FOR index = 0 TO highVal ' Count To highVal can add (Step 100}
GOSUB Disp_Graph ' Update Display
NEXT
PAUSE 5000 ' Wait 5 Seconds Then Repeat
LOOP ' Forever
STOP
' -----[noparse][[/noparse] Subroutines ]-----------------------------------------------------
Disp_Graph:
perCent = ((index * 100) / highVal)
' Draw index, highVal and perCent Values. This line can be removed.
SEROUT LCD, Baud, [noparse][[/noparse]LcdLine1, DEC5 index, "/",
DEC5 highVal, "=", DEC perCent, "%"]
' Draw Header And Left-Most, Solid Blocks
SEROUT LCD, Baud, [noparse][[/noparse]LcdLine2, "0%", REP 4\(perCent MIN 1 - 1 / 10)]
' Draw Partial Block
IF perCent > 0 THEN SEROUT LCD, Baud, [noparse][[/noparse](perCent - 1 / 2) // 5]
' Draw Right-Most, Blank Blocks And Footer
SEROUT LCD, Baud, [noparse][[/noparse]REP 32\10 - ((perCent + 9) / 10), "100%"]
RETURN
Download_Chars:
FOR index = 0 TO 72 ' Download Custom Characters
NEXT
highVal = 5000 ' You can change this value to any
' Non-Zero value
Main:
DO
NEXT
LOOP ' Forever
STOP
Disp_Graph:
perCent = (index / (highVal / 100)) ' Calculate Percent Value
SEROUT LCD, Baud, [noparse][[/noparse]LcdLine3, DEC5 index, " / ", DEC5 highVal]
SEROUT LCD, Baud, [noparse][[/noparse]LcdLine1, "0% ", REP 4\(perCent MIN 1 - 1 / 10)]
SEROUT LCD, Baud, [noparse][[/noparse]REP 32\10 - ((perCent + 9) / 10), DEC perCent, " %"]
SEROUT LCD, Baud, [noparse][[/noparse]LcdBLon ,LcdLine2,5,7,7,7,7,7, 6," KW"]
RETURN
Sam
Sam
Post Edited (sam_sam_sam) : 5/4/2010 2:35:01 PM GMT
Sam
Chris Savage
Parallax Engineering
also how do you scale the bar graph as well
Sam
Chris Savage
How do you take the data that you have from the ADC part of the code and Put in·to the Bar Graph part of the code
There is where I am··I am ·REAL·Lost or just have REAL big brain f
Sam
Post Edited (sam_sam_sam) : 5/5/2010 8:33:49 PM GMT
Chris Savage
Chris Savage
Chris Savage
Could you also post the code that you used
Thanks for your help
Sam
Yep, got the programs and code done last night here at work, however I had forgotten when I got home that my main PC is down and the HD had just arrived. I didn't have time to install it last night. I will get it back up tonight though. If you're not sure what I am talking about, see this post.
Or this one.
Chris Savage
I do understand and I did read·that post on your web site
Please take a much as you need I am in no big hurry· I just want to know how you do this
Thanks for you time and help in this project
Sam
Chris Savage
Episode 5: Merging Programs Part 1 of 2
Episode 6: Merging Programs Part 2 of 2
Chris Savage
That was a GREAT how to do video
·············································· That help alot
········································································ ·Thanks
····························································································· I got it to work
Sam
Chris Savage
The second part video (Episode 6) has been fully updated and posted at the link above. It gives more details than I thought I had time for originally.
Chris Savage
Thanks for taking the time to make this video. You explain alot in a clear manner that helps people like me really understand the thinking process in merging programs together. Well done!
Shawn Lowe
When all else fails.....procrastinate!
Chris Savage
The info that you add at the end ·WAS GREAT··that helps alot Thank for all of your help
Sam
' ========================================================================= ' ' File...... MAX186 Bar Graph (Hi-Res_Advanced).bs2 ' Purpose... Demostrate A Hi-Res Advanced Bar Graph ' Author.... Sam ' E-mail.... [url=mailto:sam1030@comcast.net]sam1030@comcast.net[/url] ' Started... 5-12-2010 ' Updated... ' ' {$STAMP BS2} ' {$PBASIC 2.5} ' ' ========================================================================= ' ' I want to thank Chris Savage for his help writing the line of ' code to make ADC chip work with the Bar graph ' ' -----[noparse][[/noparse] Program Description ]--------------------------------------------- ' This program shows how to draw an Advanced Bar Graph Display on a ' Paralax 2X16 Serial LCD. The subroutine needs only to know the highVal ' and the current index to display the Percent and Bar Graph. Feel free to ' change the code to suit your own application. ' ' NOTE: This code includes other unused constants for the display so you ' have them, however if not used, these do not take up any memory in the ' BASIC Stamp, so they are good to have available. ' ' You can change the value of highVal and see how it affects things. ' highVal and index are Word values and should never exceed 65535. ' -----[noparse][[/noparse] Revision History ]------------------------------------------------ ' Increased resolution from 255 to 65535. ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- LCD PIN 15 ' LCD Serial I/O Pin CS PIN 1 ' Chip Select Clock PIN 0 ' Clock DataOut PIN 3 ' DataOut DataIn PIN 2 ' DataIn ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- LcdBkSpc CON $08 ' Move Cursor Left LcdRt CON $09 ' Move Cursor Right LcdLF CON $0A ' Move Cursor Down 1 Line LcdCls CON $0C ' Clear LCD (Use PAUSE 5 After) LcdCR CON $0D ' Move Pos 0 Of Next Line LcdBLon CON $11 ' Backlight On LcdBLoff CON $12 ' Backlight Off LcdOff CON $15 ' LCD Off LcdOn1 CON $16 ' LCD On; Cursor Off, Blink Off LcdOn2 CON $17 ' LCD On; Cursor Off, Blink On LcdOn3 CON $18 ' LCD On; Cursor On, Blink Off LcdOn4 CON $19 ' LCD On; Cursor On, Blink On LcdLine1 CON $80 ' Move To Line 1, Column 0 LcdLine2 CON $94 ' Move To Line 2, Column 0 LcdCC0 CON $F8 ' Define Custom Char 0 LcdCC1 CON $F9 ' Define Custom Char 1 LcdCC2 CON $FA ' Define Custom Char 2 LcdCC3 CON $FB ' Define Custom Char 3 LcdCC4 CON $FC ' Define Custom Char 4 LcdCC5 CON $FD ' Define Custom Char 5 LcdCC6 CON $FE ' Define Custom Char 6 LcdCC7 CON $FF ' Define Custom Char 7 Baud CON 396 ' 2400 Kbps (BS2) Cnts2Mv CON $00F6 ' x 245 ' -----[noparse][[/noparse] Variables ]------------------------------------------------------- work VAR Byte ' Work Variable index VAR Word ' Current Value Of Count/Loop highVal VAR Word ' Highest Value Expected perCent VAR Byte ' Percentage result VAR Word ' Conversion Result CH0 mVolts VAR Word ' Result0 --> mVolts ' -----[noparse][[/noparse] EEPROM Data ]----------------------------------------------------- CC0 DATA LcdCC0, $10, $10, $10, $10, $10, $10, $10, $10 CC1 DATA LcdCC1, $18, $18, $18, $18, $18, $18, $18, $18 CC2 DATA LcdCC2, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C CC3 DATA LcdCC3, $1E, $1E, $1E, $1E, $1E, $1E, $1E, $1E CC4 DATA LcdCC4, $1F, $1F, $1F, $1F, $1F, $1F, $1F, $1F ' -----[noparse][[/noparse] Initialization ]-------------------------------------------------- HIGH LCD ' Setup Serial Output Pin PAUSE 100 ' Give LCD Time To Settle Download_Chars: FOR index = 0 TO 45 ' Download Custom Characters READ CC0 + index, work ' Read EEPROM Data SEROUT LCD, Baud, [noparse][[/noparse]work] ' Send To LCD CGRAM NEXT SEROUT LCD, Baud, [noparse][[/noparse]LcdOn1, LcdBLon] ' Turn LCD Display & Backlight On ' Backlight Only On Backlit Models PAUSE 10 ' Allow LCD Time To Settle highVal = 4095 ' You can change this value to any ' Non-Zero value ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Main: DO SEROUT LCD, Baud, [noparse][[/noparse]LcdCls] GOSUB Read_ADC ' Read ADC Value index = result ' Copy to index GOSUB Disp_Graph ' Draw Graph PAUSE 100 ' Small Delay LOOP ' Forever ' -----[noparse][[/noparse] Subroutines ]----------------------------------------------------- Disp_Graph: perCent = (index / (highVal / 100)) ' Calculate Percent Value ' Draw index, highVal and perCent Values. This line can be removed. ' SEROUT LCD, Baud, [noparse][[/noparse]LcdLine1, DEC5 index, "/", ' ] ' Draw Header And Left-Most, Solid Blocks SEROUT LCD, Baud, [noparse][[/noparse]LcdLine1, "0_", REP 4\(perCent MIN 1 - 1 / 10)] ' Draw Partial Block IF perCent > 0 THEN SEROUT LCD, Baud, [noparse][[/noparse](perCent - 1 / 2) // 5] ' Draw Right-Most, Blank Blocks And Footer SEROUT LCD, Baud, [noparse][[/noparse]REP 32\10 - ((perCent + 9) / 10), DEC perCent, "%" ] RETURN Read_ADC: LOW CS ' Enable ADC SHIFTOUT DataIn, Clock, MSBFIRST, [noparse][[/noparse]%11001101] ' Select CH1, Single-Ended [noparse][[/noparse]%1XXX1101] SHIFTIN DataOut, Clock, MSBPOST, [noparse][[/noparse]result\12] ' Read ADC HIGH CS ' Disable ADC mVolts = result */ Cnts2Mv ' Convert To Millivolts RETURN▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Sam
