SMD Crystal for Prop
I have been looking a little around in order to find (if existing) some crystal for the Prop with a minimal footprint. SMD would be great.
Any advice? Parallax does not sell any...that's a shame [noparse]:([/noparse]
Nicola
Nicola
Propeller Forums RSS Feed!
Gadget Gangster - Share your Electronic Projects
Style and grace : Nil point
We will generally sell anything that we stock, whether or not it is on the web page. You may be interested in the 10 MHz crystal used on the Spin Stamp. If it would work, you can call our sales department at 1-888-512-1024 and ask for part number 253-10000.
— David Carrier
I was only trying to point out that there were other types than the "tin box" types. I an afraid that I recycle almost everything, that is most of it is dragged off of scrap. If only I could find some scrapped boards with Props on them.
If I were to order anything it would have to go through the Finance Controller, and SHE wouldn't like it. Every Prop is a quarter of a pair of shoes (at English Prop prices) and that just would not do!
Hey-Ho.
Sorry, I meant to address Nicola with that last response.
— David Carrier
Digikey XC670CT-ND
But, it's not exactly small...
mpark has·a recent thread where he got a watch crystal working. That's probably the smallest option...
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
http://forums.parallax.com/showthread.php?p=897202
*Peter*
*Peter*
I can say though that I really like the small footprint of these crystals as I have always resented having to use the "sasquatch" footprint of the HC49 smd version which is such a nuisance to route around and also keep noise free.
*Peter*
Clusso would get a CP/M system into one of those.
thanks...I got that was for me [noparse]:)[/noparse]
It is nice for me, when I buy for Parallax, to be able also to buy all those little thing I need to get my prop "spin".
I usually buy my prop from you and then I go looking around for all other pieces from other sites....which add costs and loss of time...that's why my comment
Thanks for you tip!
Nicola
Attached is a photo of a board I designed a couple of years ago. It has 3 props on it. I made the pads for the crystal large enough that I could use regular "Cans" but also has a surface mount trace as well.
It's been long enough ago that I don't remember who makes/made them but if you look at props "B" and "C" they have a small surface mount 5 mhz oscillator/crystal mounted next to them. It took a bit of searching on Digikey, but SOMEBODY makes them ( or at least did a couple of years ago )
I don't even know whether they ARE crystals or ceramic oscillators but I do know that they work great for all the boards I've built. No problems with TV, Vga, or anything that I have done related to timing.
I know I have some laying around somewhere but try to find them on Digikey first. If you don't find 'em I'll dig up an old Digikey purchase order and see what the numbers were.
Ken B.
" Anything worth doing... is worth overdoing. "
··············································· ( R.A.H. )
— David Carrier
Tracy Allen
www.emesystems.com
Another thing, I thought the cut of the crystal would be different from the HC49 varieties but a careful examination of the datasheets reveals that these crystals have the same specs as the HC49 units, although the maximum operating temperature appears to be 10'C lower.
*Peter*
My issue with that cylindrical crystal is that I have to certify operation to -40 and +85 Celsius, and it is only rated -20 to +70. The Jauch crystals are almost all custom order, but they drop to around 65 cents each on full reels. That is for a -40 to +105 °C part.
Tracy Allen
www.emesystems.com
BTW I am thinking of making RamBlade II (slightly smaller pcb than RamBlade for sbc only) to fit into a Hammond Translucent Blue 1551FLTB box which is 50x35x15mm.
Mouser have 5MHz cylindrical crystals in stock au.mouser.com/ProductDetail/ABRACON/AB308-5000MHZ/?qs=sGAEpiMZZMsBj6bBr9Q9aUe%252bp9Tek3UMjFhI3QXVlxo%3d at 40 cents each in 100 lots. The operating temperature is quoted as being 0 to 70 'C which is normal commercial temperature range for any device.
I like the price of the Jauch crystals at 65 cents each "on full reels''!!!
EDIT: I have attached a screenshot of some of the different crystal footprints I have built in my Protel library. Notice the crystal that takes up the least amount of copper and has the terminals closest together is....
*Peter*
Post Edited (Peter Jakacki) : 5/7/2010 12:49:55 AM GMT
That would be a second use for the X in the part number, thats where the glue goes.
What is the reasoning for this? I haven't had any problems with the 18pF. Any foreseeable problems with this? Or is there a SMD crystal with 20pF and 85C spec someone can point me to?
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Some of my objects:
MCP3X0X ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library - Don't allow strings to be the bane of the Propeller, bend them to your will!
Fast Inter-Propeller Comm - Fast communication between two propellers (1.37MB/s @100MHz)!
www.golledge.co.uk/docs/products/xtlspec.htm
You probably won't find them at suppliers like Digi-Key, though.
Leon Heller
Amateur radio callsign: G1HSM
They are available in 10MHz, 12MHz, 13MHz and 14.31818MHz for PLLx8. Pricing <60c ea per 100.
*Peter*
