Easy Bluetooth and Propeller
I've been asked to post this code to see if we can figure out what is goign on.
Essentially, when ever pin 0 is grounded, the variables will display a value of 50. If any pins higher than pin 0 are grounded, the highest pin will be assigned an integer and the value calculated (if pin 9 is the heighest, it will report a value of 140). However, if the program looks at more than 8 pins at once (sensors_start = 0 and sensors_end > 7, it does not report the correct values. With sensors_end set to 8, this program is returning a value of 130 but pin 0 is the only pin that is grounded.
CON
_clkmode = xtal1 + pll16x 'Feedback and PLL multiplier
_xinfreq = 5_000_000 'External oscillator = 5 MHz
sensors_start = 0 'Define lowest whisker port
sensors_end = 8 'Define highest whisker port
OBJ
pst:"Parallax Serial Terminal" 'Start Terminal for visual output
Debug:"FullDuplexSerial"
VAR
long a
long b
long c
long d
long e
long f
long g
long h
long i
long j
long k
long l
long m
long n
long o
long p
long q
long r
long s
long t
PUB WhiskerTest
pst.start(9600)
repeat until a#>=0 'Repeat code segement until variable has a value > 0
if ina[noparse][[/noparse]sensors_start] == 0 'If pin[noparse][[/noparse]sensors_start] is grounded (= 0)
repeat 10_000 'Repeat whisker check 10,000 times
a#>= (>|(ina[noparse][[/noparse]sensors_end..sensors_start]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20
'Multiple pin value by 10 and add 40 for height
'Record maximum value of 10,000 trials as variable
pst.dec(a) 'Dsiplay variable
pst.newline 'Start a new line in display
else 'If pin[noparse][[/noparse]sensors_start] is not grounded
a:= 0 'Variable = 0
if a#>0 'See if previous variable was detected
waitcnt(clkfreq/5+cnt)
repeat until b#>=0 'Repeat code segement until variable has a value > 0
b#>= (>|(ina[noparse][[/noparse]sensors_end..sensors_start]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20
pst.dec(b) 'Dsiplay variable
b:= 0 'Variable = 0
if b#>0 'See if previous variable was detected
repeat until c#>=0 'Repeat code segement until variable has a value > 0
c#>= (>|(ina[noparse][[/noparse]sensors_end..sensors_start]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20
pst.dec(c) 'Dsiplay variable
c:= 0 'Variable = 0
if c#>0 'See if previous variable was detected
repeat until d#>=0 'Repeat code segement until variable has a value > 0
d#>= (>|(ina[noparse][[/noparse]sensors_end..sensors_start]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20
pst.dec(d) 'Dsiplay variable
d:= 0 'Variable = 0
if d#>0 'See if previous variable was detected
repeat until e#>=0 'Repeat code segement until variable has a value > 0
e#>= (>|(ina[noparse][[/noparse]sensors_end..sensors_start]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20
pst.dec(e) 'Dsiplay variable
e:= 0 'Variable = 0
if e#>0 'See if previous variable was detected
repeat until f#>=0 'Repeat code segement until variable has a value > 0
f#>= (>|(ina[noparse][[/noparse]sensors_end..sensors_start]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20
pst.dec(f) 'Dsiplay variable
f:= 0 'Variable = 0
if f#>0 'See if previous variable was detected
repeat until g#>=0 'Repeat code segement until variable has a value > 0
g#>= (>|(ina[noparse][[/noparse]sensors_end..sensors_start]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20
pst.dec(g) 'Dsiplay variable
g:= 0 'Variable = 0
if g#>0 'See if previous variable was detected
repeat until h#>=0 'Repeat code segement until variable has a value > 0
h#>= (>|(ina[noparse][[/noparse]sensors_end..sensors_start]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20
pst.dec(h) 'Dsiplay variable
h:= 0 'Variable = 0
if h#>0 'See if previous variable was detected
repeat until i#>=0 'Repeat code segement until variable has a value > 0
i#>= (>|(ina[noparse][[/noparse]sensors_end..sensors_start]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20
pst.dec(i) 'Dsiplay variable
i:= 0 'Variable = 0
if i#>0 'See if previous variable was detected
repeat until j#>=0 'Repeat code segement until variable has a value > 0
j#>= (>|(ina[noparse][[/noparse]sensors_end..sensors_start]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20
pst.dec(j) 'Dsiplay variable
j:= 0 'Variable = 0
if j#>0 'See if previous variable was detected
repeat until k#>=0 'Repeat code segement until variable has a value > 0
k#>= (>|(ina[noparse][[/noparse]sensors_end..sensors_start]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20
pst.dec(k) 'Dsiplay variable
k:= 0 'Variable = 0
if k#>0 'See if previous variable was detected
repeat until l#>=0 'Repeat code segement until variable has a value > 0
l#>= (>|(ina[noparse][[/noparse]sensors_end..sensors_start]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20
pst.dec(l) 'Dsiplay variable
l:= 0 'Variable = 0
if l#>0 'See if previous variable was detected
repeat until m#>=0 'Repeat code segement until variable has a value > 0
m#>= (>|(ina[noparse][[/noparse]sensors_end..sensors_start]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20
pst.dec(m) 'Dsiplay variable
m:= 0 'Variable = 0
if m#>0 'See if previous variable was detected
repeat until n#>=0 'Repeat code segement until variable has a value > 0
n#>= (>|(ina[noparse][[/noparse]sensors_end..sensors_start]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20
pst.dec(n) 'Dsiplay variable
n:= 0 'Variable = 0
if n#>0 'See if previous variable was detected
repeat until o#>=0 'Repeat code segement until variable has a value > 0
o#>= (>|(ina[noparse][[/noparse]sensors_end..sensors_start]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20
pst.dec(o) 'Dsiplay variable
o:= 0 'Variable = 0
if o#>0 'See if previous variable was detected
repeat until p#>=0 'Repeat code segement until variable has a value > 0
p#>= (>|(ina[noparse][[/noparse]sensors_end..sensors_start]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20
pst.dec(p) 'Dsiplay variable
p:= 0 'Variable = 0
if p#>0 'See if previous variable was detected
repeat until q#>=0 'Repeat code segement until variable has a value > 0
q#>= (>|(ina[noparse][[/noparse]sensors_end..sensors_start]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20
pst.dec(q) 'Dsiplay variable
q:= 0 'Variable = 0
if q#>0 'See if previous variable was detected
repeat until r#>=0 'Repeat code segement until variable has a value > 0
r#>= (>|(ina[noparse][[/noparse]sensors_end..sensors_start]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20
pst.dec(r) 'Dsiplay variable
r:= 0 'Variable = 0
if r#>0 'See if previous variable was detected
repeat until s#>=0 'Repeat code segement until variable has a value > 0
s#>= (>|(ina[noparse][[/noparse]sensors_end..sensors_start]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20
pst.dec(s) 'Dsiplay variable
s:= 0 'Variable = 0
if s#>0 'See if previous variable was detected
repeat until t#>=0 'Repeat code segement until variable has a value > 0
t#>= (>|(ina[noparse][[/noparse]sensors_end..sensors_start]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20
pst.dec(t) 'Dsiplay variable
t:= 0 'Variable = 0
Dave
Dave Andreae
Parallax Tech Support·
Dave
Dave Andreae
CON _clkmode = xtal1 + pll16x 'Feedback and PLL multiplier _xinfreq = 5_000_000 'External oscillator = 5 MHz sensors_start1 = 0 'Define lowest whisker port sensors_end1 = 7 'Define highest whisker port sensors_start2 = 8 sensors_end2 = 15 sensors_start3 = 16 sensors_end3 = 19 OBJ pst:"Parallax Serial Terminal" 'Start Terminal for visual output Debug:"FullDuplexSerial" VAR PUB WhiskerTest|a,a1,a2,a3 debug.start(27,26,0,9600) repeat 'Repeat code segement until variable has a value > 0 if ina[noparse][[/noparse]sensors_start1] == 0 'If pin[noparse][[/noparse]sensors_start] is grounded (= 0) repeat 10_000 'Repeat whisker check 10,000 times a1#>= (>|(ina[noparse][[/noparse]sensors_end1..sensors_start1]^$ff)*10+40) 'Assign lowest pin a value of 1 and the highest pin 20 a2#>= (>|(ina[noparse][[/noparse]sensors_end2..sensors_start2]^$ff)*10) 'Multiple pin value by 10 and add 40 for height a3#>= (>|(ina[noparse][[/noparse]sensors_end3..sensors_start3]^$f)*10) a:=a1+a2+a3 'Record maximum value of 10,000 trials as variable debug.dec(a) 'Dsiplay variable debug.str(string(13)) 'Start a new line in display else 'If pin[noparse][[/noparse]sensors_start] is not grounded a:= 0Seems to work. Once I have the whisker assembly, I'll know for sure but preliminary testing shows promise.
