Rename a file with FSRW? — Parallax Forums
JonnyMacJonnyMac Posts: 9,688
edited 2010-05-04 20:03 in Propeller 1
I'm tired so I may be looking right past the obvious... but is there a way to rename a file with FSRW?
Jon McPhalen
Hollywood, CA
    edited 2010-05-04 15:48
    I don't think so. I know the original FSRW 2.4 didn't have a rename operation and I don't think that was added in FSRW 2.6
  • JonnyMacJonnyMac Posts: 9,688
    edited 2010-05-04 15:54
    Thanks, Mike; I guess I'll just delete said file.
    Jon McPhalen
    Hollywood, CA
    edited 2010-05-04 16:41
    The directory is just a specially formatted file, so you could write your own rename method.· I might get around to doing that tonight after work.· Hopefully, FSRW will allow me to write to the directory.· I am developing a standard C-function interface to FSRW for CLib, and I wrote a readdir method to provide the information I needed for directory listings.· Take a look at the attached fsrwif.spin file.· Wikipedia has a good description of the directory structure under "File Allocation Table".
    Dave
  • rokickirokicki Posts: 1,000
    edited 2010-05-04 17:00
    No, fsrw supports neither directory "write" nor rename. Rename is not too hard but you *do* need to avoid duplicate names, delete a
    file that is renamed-over (or error-out if you decide on those semantics), and said deletion must of course free the cluster chain.
    FSRW was never intended to be a full POSIX filesystem; that's more Kye's ambition than mine.
  • KyeKye Posts: 2,200
    I have two more weeks of finals (I'll be done on Tuesday next week) After that I'll be working on the FATEngine soon and releasing it with all wanted features.
    Cheers,
    Nyamekye,
