HB-25 Question
I have 2 Ea. 12 volt motors. Is it going to be an issue connecting them both to one HB-25? I know they will not run at full speed, but can only afford 1 HB-25 for now. Also, Do I use the battery negative side on the HB-25 to ground the motors?
Post Edited (NWCCTV) : 5/4/2010 4:30:12 AM GMT
You might consider building two H-bridges or buying a pair of ready-made H-bridges rather than an HB-25 if you can't afford two of them.
http://www.parallax.com/Portals/0/Downloads/docs/prod/motors/HB-25MotorController-V1.2.pdf
2 operation modes: control 1 or 2 HB-25’s independently from a single I/O line
That's 2 HB's, not 2 motors.
What happens with the back EMF when the motors are suddenly reversed?
I'm sure Parallax would't recommend it. They didn't recommend 2 HB-25's to drive one .8 HP motor - even though the the combined output of 2 HB-25's equaled the current requirements of the .8 HP motor (50 Amps).
Post Edited (Wildatheart) : 5/4/2010 5:03:37 AM GMT
