question on ping sensor
Hi everyone.
I have a little question. Is it possible to see the differance with a ping sensor (item code 28015) for human aprocing the sensor or going away from te sensor.
I need a way to detekt with a propeller that is fix located (aganst the wall abouve a door) that someone is aproching or leaving. I was thingking about the ping sensor. Normaly it is mounted on a robot to detekt obsticals but now it is in revers. Mounted on the opstical (wall) and telling that the object (human/child) is comming toward the sensor or going away. It is perhaps importand to say that is is intended to install it higher than the persons on an angle looking downwards. This is only done because of practical reason.
Is it fast enough in detektion if someone is normal walking?
Has someone any experiance on this or comment. I'm not sure if it is possible and are intending to set up a test but before doing that i'm interested in any comment.
Stefan Vanhoof
Stefan Vanhoof
CON _clkmode = xtal1+pll16x _xinfreq = 5_000_000 VAR word set_dist word start_scan word end_scan OBJ ping : "PING" PUB Moving ''This PUB will return TRUE if the object is towards the sensor, and will return false if the ''object is moving away from the sensor ping.start(0) repeat until ina == 1 set_dist := ping.Inches repeat ifnot ping.Inches == set_dist start_scan := ping.Inches waitcnt(clkfreq + cnt) end_scan := ping.Inches if start_scan > end_scan return true if start_scan < end_scan return false▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Check out my new website!!
Use the Propeller icon!!
Follow me on Twitter! Search "Microcontrolled"
Thanks for the comment. I'm going to set up a test case and look if it is possible. If I stumbel on open questions I 'll come back to this forum. You are all a gread help
Stefan
