Html Radio buttons on Parallax Internet Netburner Kit
I am trying to setup·html radio buttons on a web page displayed from a Parallax Internet Netburner Kit.·
<form name="Test" action="\example.htm" method="post">
<br>
<Input name="Nb_var40" type= "radio"·· Value="ON"<Nb_var40>">ON
<Input name="Nb_var40" type= "radio"·· Value="OFF" <Nb_var40>">OFF
<input type="submit"value="submit" > Nb_var40=<Nb_var40>
</form>
This will update the NB_var40 location, but the buttons are not updated.
Post Edited (microchip2) : 5/1/2010 7:34:54 PM GMT
<br>
</form>
This would be correct HTML but will not show selected radio button:
This would "pre-check" the radio button "off"
The problem is that if you want to use the actual value of the variable Nb_var40 to show which button is selected, the value of Nb_var40 must be "selected" for "on" and "" (empty) for off. That's not going to happen, as Nb_var40 (I presume) is not and can not be a string.
It might be easier to do this with JavaScript, so that the value of Nb_var40 can be tested in the browser and then properly set the select state of the radio button:
<script> if ( <Nb_var40> == null || <Nb_var40> == 0 || <Nb_var40> == "0" || <Nb_var40> == "N" ) { // or whatever other tests you want to do // javascript to set radio button off } else { // javascript to set radio button on } </script> <Input name="Nb_var40" type= "radio" Value="ON">ON<br /> <Input name="Nb_var40" type= "radio" Value="OFF">OFF<br /> <input type="submit"value="submit" ><br /> Status: Nb_var40=<Nb_var40>▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
The following code is still not working correctly.
<html> <head> <script type="text/vbscript"> sub MyOnload if document.Unit1.Nb_var40(0).value = "ON" then document.Unit1.Nb_var40(0).checked = "True" Else document.Unit1.Nb_var40(1).checked = "True" End if end sub </script> <title></title> </head> <body language="vbscript" onload="MyOnload"> <p><a href = "vbscript:history.back()"> Go Back </a> </p> <form name="Unit1" action="\test.html" method="post"> <br> UNIT1 <Input name="Nb_var40" type= "radio" Value="ON" language="vbscript" >ON <Input name="Nb_var40" type= "radio" Value="OFF" language="vbscript">OFF <input type="submit"value="submit" > <br> <br> Status: Nb_var40=<Nb_var40> </form> </body> </html><html> <head> <script type="text/vbscript" > sub MyOnload if ("<Nb_var40>" = "ON") then msgbox "ON" document.Unit1.Nb_var40(0).checked = "True" Else msgbox "OFF" document.Unit1.Nb_var40(1).checked = "True" End if end sub </script> <title></title> </head> <body language="vbscript" onload="MyOnload"> <p><a href = "vbscript:history.back()"> Go Back </a> </p> <form name="Unit1" action="\test.html" method="post"> <br> UNIT1 <Input name="Nb_var40" type= "radio" Value="ON">ON <Input name="Nb_var40" type= "radio" Value="OFF">OFF <input type="submit"value="submit"> <br> <br> Status: Nb_var40=<Nb_var40> </form> </body> </html>The pink responds well to JavaScript. I am no expert on it but here is what I did:
Open a notepad to put your Script in
function setRadioButton1(param){ if ( param == "ON" ) { document.getElementById("radOn1").checked='checked'; } else { document.getElementById("radOff1").checked='checked'; } } function setRadioButton2(param){ if ( param == "Heat" ) { document.getElementById("radOn2").checked='checked'; } else { document.getElementById("radOff2").checked='checked'; } }Save as app.js (file type- All Files, Encoding UTF-8)Put that file in the PINK home directory right next to your index file.
On my main index page I have:
Mini-Split<br /> <Input id="radOn1" name="Nb_var93" type= "radio" Value="ON">ON<br /> <Input id="radOff1" name="Nb_var93" type= "radio" Value="OFF">OFF<br /><input type="submit"value="submit" ><br /> Status: <Nb_var93> <script> setRadioButton1("<Nb_var93>"); </script> Heat/AC<br /> <Input id="radOn2" name="Nb_var94" type= "radio" Value="Heat">Heat<br /> <Input id="radOff2" name="Nb_var94" type= "radio" Value="AC">AC<br /><input type="submit"value="submit" ><br /> Status: <Nb_var94> <script> setRadioButton2("<Nb_var94>"); </script>Hope this helps someone.
