AD590 Chip......>>>>>> ADC raw data kelvin to degrees Celsius how do I the ma
·Here is the· conversion·· ·1 Kevin = -272.15 degrees Celsius
Here is the data sheet to the AD590 Chip
http://www.analog.com/en/other-products/militaryaerospace/ad590/products/product.html
Thanks to anyone that can help
·Now wanting to learn Spin· Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 4/26/2010 4:14:29 PM GMT
Sam
deg2C = deg2K - 27215 ' in units of 1/100 degree
Your puzzle may have more to do with how your ADC returns the data, and what language you are using.
Tracy Allen
www.emesystems.com
I can use / 12 and get 25 wich is a little off it should closer to· 30
I am using a BS2 for this Demo Board
Sam
Post Edited (sam_sam_sam) : 4/26/2010 4:55:49 PM GMT
Let's assume zero offset.
' value ADC returned here
kelvin = ADC ** 64674 ' calibration: 300 Kelvin @ 304 ADC
celsius = kelvin - 273
fahrenheit = kelvin * 9 / 5 - 460
Do you have a 1kΩ resistor to convert the current from the AD590 into Volts, being read by an ADC at 1mV per bit? If you use a 10k resistor instead, then the reading can be more accurate.
Tracy Allen
www.emesystems.com
I have 1.2 k ohm on there now
I try this and see what happen
Sam
·········································································································@·about 80* F
I changed the resister to 10k ohms and now the·result value is 1530·· |
When the resister was 1.2k ohms it was 304···························· ········|··
Is·this what I should get as a value changing the resister to 10k ohms ·········
Sam
I believe there must be something wrong electrically with your circuit. Do you have at least 5 volts across the AD590 sensor?
Math for the AD590 is very simple. The sensor produces (nominally) 1 microAmp per Kelvin. So at 300 Kelvin, the voltage across a 1000Ω resistor should be 300 mV, or across 1200Ω it should be 360mV, or across 10000Ω it should be 3000mV. Simple
mV = µA * R /1000 with µA = Kelvin, R in Ohms
300 Kelvin is near 27 Celsius or 80 Fahrenheit.
You report that the result value is 304mV with 1.2 kOhms, which would solve backwards to
Kelvin = µA = mV / 1200 = 304 * 1000 / 1200 = 253 Kelvin
That is -20 degrees Celsius, I don't think so. The result would make much more sense if you had a 1000Ω resistor, which is what I was assuming you had above. The result is even worse with the 10kΩ resistor:
Kelvin = µA = mV * 1000 / 10000 = 1530 * 1000 / 10000 = 153 Kelvin! -120 Celsius!
That bad result could be explained if there is not enough voltage across the AD590. Or maybe I am wrong about the numbers reported by your ADC. Does 304 mean 304 milliVolts?
Tracy Allen
www.emesystems.com
With a 1.2k Ohm· = 1.2 volts @ about 80* F
One is
With a 10k Ohm = 2.345 Volt @ about 80*F
The voltage reading where taken with a volt meter
I hope this helps
Sam
Please draw out or describe your circuit, including how you are powering the AD590. Are you measuring those voltages with the MAX186 program you posted above, or with a multimeter?
Those values don't make sense. For example, 1.2V across a 1.2kΩ resistor implies a current of 1 mA, which would be produced by an AD590 at 1000 degrees Fahrenheit (as if it could go that high). Do you see the problem?! At 80 °F, across 1.2kΩ, you should expect near 360mV.
Tracy Allen
www.emesystems.com
I have it the way the data sheet shows it on the top of page 7
·I found the problem why my voltage was so off was that my input ground·was not hook up on the MAX186 Chip
Now I am getting 324.1 millivolts @ about 80*F which is still of by a little I just have to find the right value resistor to get 300 millvolts
Thank for your help
Sam
Post Edited (sam_sam_sam) : 5/1/2010 4:20:35 PM GMT
