Changing Baud rate on Viniculum /Memory Datalogger
Has anyone successfully changed the baud rate to anything other than the default rate of 9600 on the Memory Datalogger when using the serial interface (non-SPI mode)? I've tried the command listed in the Vinculum FW document (v2.05) which is "SBD $4EC000" for 38,400 BPS, also tried to·issue the command at the default rate of 9600 which is "SBD $384100" which should do nothing since it's already at 9600. In·both cases, the rate changes and I can no longer talk to the datalogger until I power cycle it.
I'm using a propellor chip as the processor with a modified "parallax serial terminal " sw-based UART.
Post Edited (kanthony) : 4/30/2010 2:45:24 PM GMT
- Stephen
Jeff T.
Using defalut hex and ECS mode.
SetRamBaud := $D0 ser.tx($02) ser.tx($40) ser.tx($00) ser.tx(SetRamBaud) ser.tx($00) ser.tx($00)
