Working CRC16 code in spin for the CrystalFontz display
CannibalRobotics
OK, this is the CRC-CCITT code that works with the CrystalFontz display if you are interested.
Signature space for rent!
Send $1 to CannibalRobotics.com.
_crc := $FFFF ' initialize _crc
Repeat i from 0 to PacketSize ' Paload of bytes sent here
_crc := UpdateCRC(Packet[noparse][[/noparse]i],_crc) ' Update _crc with each byte
TSc.tx(Packet[noparse][[/noparse]i]) ' Send the byte
' Invert or adjust CRC as necessary
crcl := !(_crc & $00FF) ' Bottom 8 bits into crc low & invert
crch := !(_crc >> 8) ' Top 8 bits into crc High & invert
TSc.tx(crcl) ' complete transmission with last two CRC bytes
TSc.tx(crch)
Pri UpdateCRC(data,crc):newcrc|i,icrc
Repeat i from 0 to 7 ' go around for each bit
if ((crc ^ data) & $01)
crc := crc >> 1
crc := crc ^ $8408 ' $8408 is the 'polynomial'
else
crc := crc >> 1
data := data >> 1
return crc & $FFFF
Dave
"pycrc" is a pretty handy tool that can calculate lookup tables (and generate sample C code) for just about any flavor of CRC:
www.tty1.net/pycrc/
--Micah
It's strange, mathematically they should both produce the same result but I never could make it happen.
Go figure...
As for speed, the application is not a big data monster - it's a control application that sends 20 byte packets for display data in response to human button events. CRC is calculated by one cog and the results passed to a modified FullDuplexSerialExtended running at 19200. I have not done the math but since I've got small packets I'm pretty sure the the serial transmission is taking up most of the time here and I'm big on the simplicity.
Thanks for the input!
Jim-
· ser.rxfill("A", 10)
· repeat j from 0 to 9
··· i := ser.rx
··· crc := UpdateCRC(i, crc)
··· pdata[noparse][[/noparse]j] := i
··· i := ser.rx
The first loop takes about 400 usec per byte.· The second loop is 5 times faster at about 80 usec per byte.· This corresponds to baud rates of 25,000 and 125,000.· This means you could compute the CRC "real-time" while receiving data at 19.2 and below.· At higher rates you would need to compute the CRC after receiving the data packet, and depend on ACKs to flow control the transmitter.· BTW, my tests were run with a system clock of 80 MHz.
Dave
Thanks for the data!
Jim-
