Can the Scratchpad RAM be worn out meaning that you can only write to it so ma
If this question is in the wrong forum Please move it for me thanks
If so dose this mean 100,000 before you wear out
·I want to thank any one that can help
·Now wanting to learn Spin· Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 4/28/2010 12:23:23 PM GMT
Sam
Here is an example of what i want to do
' {$STAMP BS2px} ' {$PBASIC 2.5} value VAR Word Value1 VAR value value2 VAR Word value3 VAR value2 addr VAR Word ' EEPROM address test VAR Byte ' test byte read back Main: DO value = $1010 value2 = $2003 PUT 0,Word value, Word value2 ' write value to SP location 0 ' and value2 to SP locations 1 & 2 value = $FF ' modify variables value2 = $FFFF GET 0,Word value, Word value2 ' retrieve from Scratchpad DEBUG HEX4 ? value ' display DEBUG HEX4 ? value2 PAUSE 2000 value1 = $1111 value3 = $222 PUT 1,Word value, Word value2 ' write value to SP location 0 ' and value2 to SP locations 1 & 2 value1 = $FF ' modify variables value3 = $FFFF GET 1,Word value1, Word value3 ' retrieve from Scratchpad DEBUG HEX4 ? value1 ' display DEBUG HEX4 ? value3 LOOP▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Sam
Post Edited (sam_sam_sam) : 4/28/2010 12:32:10 PM GMT
Thank you for your reply
But it also doesn't hold its data when power cycles on and off.
That fine if it dose not hold data when the power is removed
Sam
