how to get GPS data
When I use PMB 648 GPS receiver, I always get my latitude & longitude data is null (0000.000,N & 0000.000,W). I only get my UTC data. Do you have any explanation about this problem? thanks....
Post Edited (ivica) : 4/26/2010 8:42:53 AM GMT
It normally will not work indoors. The LED has to be on steady indicating that it has aquired at least 3 satellites.
I believe the UTC time can be gotten from 1 satellite, so that's why it shows up first.
Time:
Cold Start: 42sec (Average)
Warm Start: 38sec (Average)
Hot Start: 1sec (Min.)
Can you help me what the meaning of Acquisition Time. Thanks...
ivica"
It is the time to aquire at least 3 satellites in a best case senario (very open field with no overhead objects).
You should delete your other posting as is against forums rules to double post. Edit your other posting and use the red X.
Bruce in alaska
