frequency out BS2
Is there a way to have the freqout to be constant?
The whats a microcontroller doesnt say if the freqout can remain constaint. It shows only a fre / duration.
Will a do loop command work or will there be a pause using this method?
Plug it in and find out.· How hard is that?
My next question is the freq a sine wave or what?
Is a pulsout a square wave? If so, I can easily run the sig through a butterworth 6th order filter I have laying around to get the sinewave.
FREQOUT produces a sine wave made by varying pulse frequency modulation. That is, it is made of pulses that go from 0 to 5 volts at a much higher frequency, and the density of the pulses is a good sine wave. A low-pass filter will remove the high frequency and leave the sine wave.
Tracy Allen
www.emesystems.com
