Crystal Speeds to Drive Propellers..
I have a question about different Clock crystals..
So far in the forums I've seen people using the default 5.000 mhz ones and 6.000 and now 6.250 etc.. I know that the hydra uses a 10.000 mhz crystal as does the new web pror being developed..
So what is the best to use??
If I use a 10 mhz instead of a 5 do I change the multiplier, and what will a 10 give me over 5??
I can see that a 6.25 is 25% faster and that makes sense to me especially using it with a en28j60 to get the 25 mhz ..
Could someone enlighten me on the where's and why's to use each??
New ICON coming, gotta wait for the INK to heal, now we have colour!
Leon Heller
Amateur radio callsign: G1HSM
10MHz is the highest recommended crystal speed, as far as I know.
MacGeek117
BS2: $49
SX48 Protoboard: $10
Propeller Protoboard: Priceless
www.apple.com
www.parallax.com
www.goldmine-elec.com
www.expresspcb.com
www.jameco.com
If you use a 10 MHz, PLL would be set at 8, (for 80 MHz)
Jim
Style and grace : Nil point
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com
My products: Morpheus / Mem+ / PropCade / FlexMem / VMCOG / Propteus / Proteus / SerPlug
and 6.250MHz Crystals to run Propellers at 100MHz & 5.0" OEM TFT VGA LCD modules
Las - Large model assembler Largos - upcoming nano operating system
Leon Heller
1. Overclocking
2. 6.5MHz xtal is easy to get from DigiKey
I have also used 6MHz. 6.25MHz is ideal if you want to calculate timing because the clock is 10ns.
All these overclocking ( >80MHz ) requires careful pcb design.
I also have 13.5MHz with PLL*8 for 108MHz overclocking (also easy from Digikey) but full testing has not been completed.
