Communication Protocol - Help!
Hi Everyone,
I have a serial device connected to my propeller (Easy Bluetooth Module). I have started writing an object to interface with it and have it so that I can issue a command and read the response, however the Easy Bluetooth Module sends a lot of messages to the propeller without the propeller first issuing a command.
i.e. When another bluetooth device connects to the easy bluetooth module, it tells the propeller that there is an incoming connection.
My problem is, how do I get it receiving both messages and reacting acordingly?
Working
Unknown
I have attached my code for reference.
This is urgent, if anyone can solve this problem for me I will owe them.
"powered by Propeller" domed stickers $1.50 - Find them here
Check out my Design and Technology project for my Higher School Certificate www.ecosureblog.net
The Sarah Myatt Fund - Help Sarah and Her Family Fight Quadriplegia HERE
Post Edited (computer guy) : 4/19/2010 11:15:20 AM GMT
Working
Prop------>EB (Set Name "test") Prop<------EB (Name has been set to "test")
Unknown
Prop<------EB (Incoming connection from F9:62:01:A0:17:00)
BT.Send_Data(string("Test"))
BT.Read_Real_RSSI
You can do this by using fdx.rxcheck or making a new fdx.rxavail which does not take the character from the buffer. FDX will be receiving your string and you need to check for it.
How accurate will that be? What if the EB module sends a "incomming conection" message just after you issue a "set name" command?
Also, I would like the rx command to be in a seperate cog and continuously reading the rx buffer.
Thank you
Without more information about what you are trying to accomplish it is difficult to make any specific suggestions.
I am wanting to have access to most features of the Easy Bluetooth module.
At the moment my biggest fear is missing a "Connection droped" message from the EB and still sending data. I will essentially need a "re-connect" function.
Thank you
After that, I am hoping the rest will come easily.
Thank you
I see one problem though, what if $03 or $02 is in the middle of a packet?
Thank you
As for those bytes appearing in the middle of a packet, one would hope not. In my packets, they can as the data bytes are $00 to $FF but the byte after the start byte is the number of bytes in the packet, so if that doesn't point to $04 at the end of the packet then the packet is invalid and is discarded and the code goes back to waiting for a start byte. Is there such a protocol for Bluetooth packets?
Post Edited (Dr_Acula) : 4/19/2010 2:36:09 PM GMT
Thank you
Post Edited (computer guy) : 4/19/2010 2:52:22 PM GMT
However, you are not doing synchronous transmission so it does not really matter. Could you use the basic Xmodem protocol?
I still can't understand why cognew isn't working. :-(
I have a quick question though.
With full duplex serial, if I receive $1F how do I then transmit this as "$1F" (string) to the serial line?
Thank you
edit: I have it almost working now!!!
Post Edited (computer guy) : 4/20/2010 3:39:42 AM GMT
Any ideas?
Thank you
Post Edited (computer guy) : 4/22/2010 11:05:07 AM GMT
Where's a link to the protocol spec? I'm guessing that the length segment (like a CRC segment) is probably subject to a somewhat different set of rules than packet body text. That is not unusual.
--RvnPhnx
I tried changing:
to
but that just made things worse for unknown reasons.
Thank you
The usual program sequence would be:
read a character, compare it to $02, and set the "start of packet" flag if it is $02 - once the flag is set do not check for $02
read and save/process the header data (length, type, etc.)
read and save as many characters as specified by length and calculate crc - $00 - $FF are valid characters in this block
read and save/process the trailer
read the next character and compare it to $03 - error if not $03
check received crc (if any) and set error if not matching calculated crc
Maybe you can make better sense of this and assist me with the packet receiving code.
A state machine is very simple. In your case you have a repeat loop which reads bytes from the interface. You start with state := 0, which means FIND START DELIMITER.
It's a good idea to define some constants to make the code more readable:
FIND_START_DLM = 0
READ_HEADER = 1
CHECK_CHECKSUM = 2
READ_DATA = 3
FIND_END_DLM = 4
Now you'd use a case statement which has some code for each of those constants. For example
Post Edited (MagIO2) : 4/22/2010 1:05:44 PM GMT
I think I can put this into practice with a few modifications and filling in the blanks.
Will give me a much cleaner piece of code and better functionality.
The length character tells you how long the packet is so the $03 is not a problem because you know what you are looking for. You just have to work through a block receiving the characters into a buffer.
