Xbee XCTU Range Test
Wildatheart
Has anyone run the "Range Test" in the XCTU software?
Although my Xbee's do seem to give somewhat predictable results, the Range Test in XCTU shows a small number of "good" and A LARGE number of "bad"... 'whatevers'. If I set the switch to stop on error, it stops all the time.
The transmitting Xbee BS2 is programed to generate X+1 in a loop and sending it out. I am trying to use flow control, but it's hard to tell if flow control is working or if one of the buffers are overflowing. Does anyone have knowledge of the buffer size for either the BS2 or the Xbee - whichever seems to be overflowing culprit? Perhaps flow control needs to go both ways?
Gordon
Gordon
- Stephen
But I assume that's not OP's problem - he wouldn't be getting _any_ good whatevers if he didn't have it connected properly.
I've had what I thought were surprising numbers of bad reports as well when I've run range tests (even with the units just a couple of feet apart). But at the same time, I've had very good, consistent results with the XBees in practice. I think that the retries make up for a multitude of sins, as it were.
With the rx setup connected via USB to XCTU the "Terminal" tab display window displays, and cycles accurately, the numbers 0 to 100 when the tx setup is powered. ...yet the unexpected results in the "Range Test" I should hope these are not all "retries" as you suspect. Good grief, the old 400 Mhz got it right on the first time around. This baby is supposed to be better than that. Interesting. But I would like to know more about the Range Test.
Then... earlier I asked about buffer overflow - any idea what the buffer size is (either or both the BS2 debugin and the Xbee) because it's obvious that if a key isn't pressed quickly enough to empty the buffer, an overflow is apparant.
' {$STAMP BS2}
' {$PBASIC 2.5}
' rx_flow_control with HB25 cycle.bs2
' Hardware: 2 OEM BS2 micros with 2 Xbee radios
' Receive decimal value from transmitter and
' display in DEBUG Window of receiver using flow control
' If transmitted value = 50 then cycle the bilge pump
' and then continue to wait for keypresses to accept additional decimal values
' from transmitter
' Transmitter is programed to count continuously and send values from 0 - 255
RX PIN 0 ' Receive Pin
TX PIN 1 ' Transmit Pin
RTS PIN 2 ' RTS flow control pin
[noparse][[/noparse] Variables ]
index VAR Word ' Counter For Ramping
X VAR Byte
[noparse][[/noparse] HB25 Initialization ]
HIGH TX
HB25 PIN 15 ' I/O Pin For HB-25 ' Idle transmit pin
DO : LOOP UNTIL HB25 = 1 ' Wait For HB-25 Power Up
LOW HB25 ' Make I/O Pin Output/Low
PAUSE 5 ' Wait For HB-25 To Initialize
PULSOUT HB25, 750 ' Stop Motor
PAUSE 1 ' 1 mS Delay
[noparse][[/noparse] Xbee Inlitalization ]
DEBUG CLS, "Configuring XBee for flow control", CR
PAUSE 2000 ' 2 second guard time
SEROUT TX, 84,[noparse][[/noparse]"+++"] ' Enter command mode
SEROUT TX, 84,[noparse][[/noparse]"ATD6 1",CR] ' Enable flow control
SEROUT TX, 84,[noparse][[/noparse]"ATCN",CR] ' Exit command mode
[noparse][[/noparse] Main ]
Main:
DO
DEBUG "Press a key to retrieve data in buffer", CR
DEBUGIN X
' Wait for key press
GetData:
SERIN RX\RTS, 84,100,Timeout,[noparse][[/noparse]DEC x] ' Receive data with 100mS timeout/flow control
DEBUG " ",DEC X ' Display data
IF x = 50 THEN GOSUB Motor ' Cycle bilge pump
IF x = 50 THEN GOTO Main
GOTO GetData ' Loop back for more data
Timeout: ' No data, repeat
LOOP
[noparse][[/noparse] Cycle bilge pump ]
Motor:
PAUSE 20 ' Wait 20 mS Before Ramping
FOR index = 0 TO 250 ' Ramp Up To Full Speed
PULSOUT HB25, 750 + index ' Motor 1 Forward
PAUSE 20 ' 20 mS Smoothing Delay
NEXT
PAUSE 500 ' Wait 3 Seconds
FOR index = 250 TO 0 ' Ramp Back Down
PULSOUT HB25, 750 + index ' Motor 1 Forward Slowing
NEXT
RETURN
' {$STAMP BS2}
' {$PBASIC 2.5}
' Simple_tx.bs2
' Example to transmit decimal
' values 0 to 255
X VAR Byte
HIGH TX ' Idle transmit pin
Main:
FOR x = 1 TO 100
SEROUT TX,84, [noparse][[/noparse]DEC X,CR,CR] ' Send value of X as decimal
' Second CR is added byte buffer for flow control example
PAUSE 20
NEXT
GOTO Main
