6.4" 640x480 Color LCD Module
I happened to come by 15 or so golf cart GPS systems, and one of the many fascinating parts in them are the 6.4 inch screens. I finally found the datasheets today which include the pinout, dimensions, and specs, so I would like to put these awesome LCD's in action. Here are the two .pdf's:
Physical specifications
Pinout
I think that the propeller is ideal for this. If I could first get it to simply display something such as text, then I could move on to making a mini vga monitor...
So, what do I need to do to make it happen? Has anyone dealt with an LCD with a similar pinout?
MCU Projects·- my new site where I will be posting all projects, code, etc.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
SD Card Adapter·- Add extra memory to your next Propeller project with ease!
Pinout
Rayman's 4.3" LCD thread:· http://forums.parallax.com/showthread.php?p=834931.·
Perhaps your main challenge will be obtaining a connector for the LCD's flex cable (assuming it uses one) and then likely breaking (expanding) the pins of the connector via a PCB into something to which you can readily solder/attach.· There are a couple of breakout boards available from forum members for Ray's display, but it almost for sure has a connector with more pins (60, I believe) than what yours has, but those should give you an idea of what you'd need (at least for convenient usage).· Also, the more recent thread for Rayman's 3.5" LCD has some similar information, but the thread for the 4.3" display has 25 pages of juicy details (read the first 4 or 5 to get the general idea and then skim read or pick-and-choose the updates).· It sounds like you've got a nice display there, and if you can live with 64 colors (which is not bad), connecting it with the propeller should make for a nice matchup.· You might consider hawking about 10 of them on this forum.· You might also consider offering a freebie to someone willing to give you technical assistance and/or an interface board.· Don't know if there's much hope of using one of the existing interface boards (with a different connector), but perhaps with a jumper or ten, lol.· Good luck.· Definitely seems like a good find.
I will check out that thread and try to get something done next week when I have time.
Thanks.
I only tried with Mono LCDs: propeller.wikispaces.com/MonoLCD640
Edit: I looks quite straightforward. VSync, HSync, colors, Dot clock and Dot enable signal (only active when the image data has to be accessed).
I'd tie just the colors together and use a similar method to the one I describe. It mostly should work. R/L and U/D I'd tie to GND. They should indicate the direction of the image, left to right and up down.
It does not need any extra power supplies... nice finding. Just test all the GNDs to see if they are connected together in the panel... the pinout may not match.
Ale
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
pPropellerSim - A propeller simulator for ASM development sourceforge.net/projects/ppropellersim
Post Edited (Ale) : 4/21/2010 12:07:33 PM GMT
And I would like to be able to drive this as a basic touch control pad for some home automation. i dont need full color, or more than a few updates per second, but i do desire to have full resolution..
