need help with open-collector circuit. — Parallax Forums
allieallie Posts: 109
edited 2010-04-18 22:39 in General Discussion
·Hi, I want to interface this circuit from the 7404 to a ps2502-4 opto-isolator then to the BS2p40.
·Question is this circuit from the open-collector outputs going to the 74ls00 o.k.
· p.s. when you open the file could you please·use the + magnifier, for some reason the image is garbled with out it. I,m new at the sch program so please forgive me·for the inconvince.
allie
Post Edited (allie) : 4/17/2010 11:35:20 PM GMT
  • LeonLeon Posts: 7,620
    edited 2010-04-17 23:31
    What type of schematic file is that?
    Leon Heller
    Amateur radio callsign: G1HSM
    edited 2010-04-18 04:18
    Typically, in a public forum such as this, you will want to print the file to a more common format, such as pdf, so that everyone can view it.
  • allieallie Posts: 109
    edited 2010-04-18 17:21
    Thanks for the info. How do I change it to pdf, I'm trying to do that but with out success.
    allie
    edited 2010-04-18 19:23
    You need a print driver that can print to a PDF file. I use PrimoPDF.
    edited 2010-04-18 20:56
    allie: A quick & dirty way to make a jpeg or bmp file of anything on your screen is to hit PRINT SCREEN, then paste that into any image program, even MS paint.
    HI all. Thanks for your help on posting images. I'll close this thread and open a new one with the images hopfully showing better.
    allie
