Tank project
I'm new to basic stamp programming and I'm building an rc tank. I'm hoping some knowledgeable members can check my code and left me know if I'm on the right track.· The remote control connected to the transmitter will be·a basic·forward,·reverse, left, and right control.· When a left or right button is pressed,·I want the tank to pivot·either left or right on itself.· The basic stamp chip is connected to an h-bridge for 2 motors.· Any feedback·is appreciated.··Thanks!·
' {$STAMP BS2}
' {$PBASIC 2.5}
'* pin 1 and 2 = motor 1 [noparse][[/noparse]LEFT] directional controls *
'* pin 3 = Enable for motor 1 *
'* pin 4 and 5 = motor 2 [noparse][[/noparse]RIGHT] directional controls *
'* pin 6 = Enable for motor 2 *
'******************setup******************
Left_motor_forward PIN 1
Left_motor_reverse PIN 2
Left_motor_enable PIN 3
Right_motor_forward PIN 4
Right_motor_reverse PIN 5
Right_motor_enable PIN 6
Move_Forward PIN 7
Move_Backward PIN 8
Move_Left PIN 9
Move_Right PIN 10
' All motors are off before we start
LOW Left_motor_forward
LOW Left_motor_reverse
LOW Right_motor_forward
LOW Right_motor_reverse
LOW Left_motor_enable
LOW Right_motor_enable
'***** Main ********
main:
IF (Move_Forward = 1) THEN
GOTO forward
ELSEIF (Move_Backward = 1) THEN
GOTO reverse_motor
ELSEIF(Move_Right = 1) THEN
GOTO right
ELSEIF (Move_Left = 1) THEN
GOTO left
ELSE
GOTO main
ENDIF
'*********** FORWARD ***********
forward:
'turn off motor one
'turn off motor two
DO
HIGH Left_motor_enable
HIGH Right_motor_enable
HIGH Left_motor_forward
HIGH Right_motor_forward
LOOP UNTIL (Move_Forward = 0)
PAUSE 500 'run for a 1/2 second and then move on
GOTO main
'*********** TURN RIGHT ***********
right:
'turn off motor one
'turn off motor two
DO
HIGH Left_motor_enable 'Enable motor 1
HIGH Right_motor_enable 'Enable motor 2
HIGH Right_motor_reverse
LOOP UNTIL (Move_Right = 0)
PAUSE 500 'wait here at this line in the program for 1/2 second
GOTO main
'*********** TURN LEFT ***********
left:
'turn off motor one
'turn off motor two
DO
HIGH Left_motor_reverse
LOOP UNTIL (Move_Left = 0)
PAUSE 500
GOTO main
'*********** REVERSE ***********
reverse_motor:
'turn off motor one
'turn off motor two
DO
HIGH Left_motor_enable 'turn motor 1 on
HIGH Right_motor_enable 'turn motor 2 on
LOW 1
HIGH 2
LOW 4
HIGH 5
LOOP UNTIL(Move_Backward = 0)
PAUSE 500 'wait 1/2 second
GOTO main
- Stephen
-Where's the code for receiving signals from the receiver?
"The man who smiles when things go wrong has thought of someone to blame it on."
-Lucky[size=-1][/size]
