Paintball turrent on a robot?
I friend of mine has an old paintball gun I can put on my robot, allowing me to start working with it as soon as I can. Do realize the robot isn't quite ready, but it's only two days away. I haven't ever tried this before, so my experience is quite limited, however I do intend to make it able to transition from R/C mode to automatic position and fire. Currently I only have two sonar sensors and one servo to make a turret, but I intend to upgrade my stash sometime later so all ideas are welcome.
Current capabilities of robot:
12v battery, 350 amp output
120v. 4.5 amp inverter
High strength, very little worry for weight
Medium space; been running lower and lower but there's still plenty left
This is what I can think of for a simple method (can do this upcoming week):
Servo mounted sonar turret rocks back and forth, finding edges of a person or target previously focused on in R/C mode. The two edges are then averaged together for the middle and the gun fires, running until stop command is sent.
Complex method (requires me to get more cash):
One servo mounted sonar focuses on the person, getting the coordinates for the gun to fire. For improved accuracy, a 200mw laser shines on that person and when pared with a photo sensor is used to determine factors such as height. Two side sensors, whether it's lasers or something else, focus to the edge of the barrel's end determining the angle of which the paintballs are coming out, whether due to wind or other factors. This is then made up for in the gun's angle. Also, possibly with a color sensor or something else, I hope to also be able to detect hits, thereafter deciding whether to keep firing or not.
Anyone with more experience wish to add to or bash my ideas? I'd much rather not have to learn the hard way if I don't have to!
Pi aren't squared, pi are round. Cornbread are squared!
http://www.youtube.com/watch?v=yuWY2X3sYT0
·http://www.paintballsentry.com/
Jim
BTW--I just got the gun and an old xbox joystick to control the robot with. I'll take pictures of it and anything new tomorrow if I can; if I'm too busy I'll have it up Sunday.
I've been thinking about a bigger robot, but one thing holding me back is the thought of a software bug coupled with an out of control robot. Small ones are easier to control if something goes wrong.
Most definitely!!!
This is upgrade #1, essential & absolutely required - not an option.
Here's the one I installed:
www.killerrc.com/products/products/killswitch.php
Anyway I've been working on the control board, but unfortunately I can't do too much more until after 10 tonight. I posted a pic for those who are curious, and on it so far is the audio, most of the sd, and part of the relay power/amplifier and servo circuit. Also, in case any of you know, do I need a 3.3v pull-up on the sd portion?
Hey man, the first couple pictures, I thought it was a toy!
Out of curiosity, how will you determine elevation!? That'll be a trick [noparse]:)[/noparse]
"puff"...... Smile, there went another one.
