Why wont it work?
Gramps
Ok, first (hopefully not dumb) question..........
My steering motor is a 12v- 2 amp windshield wiper motor. (About 100 degrees turning end to end)
To control it with the Stamp, use a $50 parallax HB-25 motor controller.
OR:
How 'bout this..?
Disassemble a servo. Remove the gearing.
Remove the pot and extend the wires and glue it to the wiper motor shaft.
Disconnect the servo motor wires and extend them to two 5 volt relays with diodes in line to sense polarity reversing.
Relays control the wiper motor.
Heavy lifting for under $15!
OR:
How 'bout this..?
Clearly the apple didn't fall far from the tree Gramps/OBC Dad!
Post Edit -- malaprop
Post Edited (PJ Allen) : 4/16/2010 12:55:44 PM GMT
You are my kind of tinkerer
I'd probably make a homemade H-bridge from
large discreet transistors to control a 2amp motor.
And rig up an optical shaft encoder to keep precise
track of motor movement.
But that's just me.
I once entertained the idea of controlling
a starter motor with a prop...but it was all
just so messy and greasy
Couple of problems with trying the idea.
My bot’ is in Mongolia and i’m in Korea.
The only servo here is the good one that came with the Stamp.
An old servo with smoked gears might be a good test case.
Ya, Was wondering about buzzing, too. Thought, maybe, just leaving the little servo motor in the circuit might help.
Holly, Please send a sample H bridge that would work in this app. The ones i looked at on the web were pretty complicated.
This page has good drawings of the type of 6 transistor
bridges I usually make. Of course you would need to substitute
larger transistors for the 3906, 3904 as they won't even handle 1 amp.
It takes two output pins to drive them...just make certain your code
NEVER sets both pins high at the same time or you will have SMOKE
These designs also allow you to deliver an ac output using
a controller chip and it's single polarity power supply....very useful
sometimes.
www.beam-wiki.org/wiki/Mark_Tilden's_6-transistor_H-bridge
@Gramps: I'm a relay user myself, and I'm convinced that real men·build H-bridges from relays! Attached is my favorite design that uses small transistors to switch two SPDT relays. This method WON'T smoke from a software error. You can size the relays to power any size motor you like. The relays give full forward & reverse, as well as dynamic braking and motor coasting (two very different ways to stop a motor). Try it, you'll like it! Just get the parts from your local Korean Radio Shack, unless the Mongolian Radio Shacks are better!
LOL!
I have built quite a few different ones before but this one is designed to be run at high switching frequencies without heat-sinks. My simulations show that I can easily run to 100kHz especially if I allow for a little inductance in the supply to limit the switching peaks. OK, I haven't actually built one yet but because of my experience and the sims I am very confident of this one. I will probably cobble one together on some breadboard to check it out although I already have the pcb designed.
I use these as tiny 1.8" x 0.8" quad half-bridge modules for driving high-current 24V motors at 10 amps from the Propeller. My external control circuits also include a dedicated micro on the outputs and I/O lines that monitors fault conditions and overrides the control lines if needed.
If anyone is interested in a real tough and cheap MOSFET bridge then have a look at this web page I did up docs.google.com/View?id=ddgq8k4b_1d7j4d2fh
Remember, no heat-sinks and no smoke, and cheap.
*Peter*
Well, we think alike, that is, keep it simple, cheap and innovative!
I have another month in Seoul, and hope to get through the WAM instruction book. Than on to the States perhaps for the summer. Might get up to see Jeff and even make an EXPO.
later, phil
