How the motion sensor light affect to ultrasonic sensor distance
Hi everyone,
Cuold you please tell me how the motion sensor light affect to ultrasonic sensor distance. The smart sensor doesn't work properly in the range of motion sensor light.
Thank you for your time.
- Stephen
When I use the Ultrasonic distance sensor to detect object in this room, it not work properly. The number appear on the Parallax LCD screen is not stable. It doesn't detect object greater than 5 inches far from the sensor.
I have built two ultrasonic distance sensors. I put them opposite side ( face to face), then put one square ft cardboard between them. Both of them work very well at the hall way of the LAB room. They doesn't interfere each other.
How ·the DT-205 sensor affect to the ultrasonic distance sensor?
An Nguyen
It seems the DT-205 sensors are flooding the room with their transmitted ultrasonic signals which are confusing the Distance Sensor. Your distance sensor relies on putting out at pulse and then listen for the echo. If another transmitter is putting out a pulse at the same time it will give you incorrect results.
Jim
Thank you very much.
An
- Stephen
In ultra sonic sensors what happens is that its sends the waves and the reciever waits for the waves to hit it back. So far the sensor more are the chances are the waves will be not accurate by they are just very very accurate bcoz they are built according to that. But they only get little bit changed if there is humidity in the air. Or something.
Or other devices working like that which is intrupt them.
According what i had learnt till now light may affect the ultra sonic sensor according to me but its impossible that u will not get readings. Bcoz light will affect with there small tiny dust particles which fly in air will come at the front of the wave and which may act as a dust and absorbs the sound wave but its not possible that all of the wave will get absorbed.
Rest all depends upon at which kind of surface u are hitting the waves. Is it diverted to some other angle which does not make 90 to it. So the waves doesnt come back.
And if u try to notice ultra sonics sensor also make click kind of sound when they gets the reading.
I am just student. I maybe wrong
