How do you get the Stamp to stop running the code?
Must have missed something in the intro.
Or clear the memory or something?
Tanks!!!
Tanks!!!
Use a program like this to remove the previous set of instructions
If you convince yourself that something is impossible before you even try; you are sure to prove yourself right.
- Stephen
- Stephen
- Stephen
This will also help
And there is no way out to stop your stamp to stop reading code which is already there. So just power it off. Or hold reset BUTTON till the time u power it off.
Hope it will help u.
Use pause between the loops so u know where it is before something really wrong happens.
or Always keep another program open which doesnt do any thing just run that or press ctrl + R
I am just student. I maybe wrong.
